Drive discussion: trs.  3's. And 5's >
Old 01-05-2015 | 05:27 AM
  #81
parts availability. i don't think it is that big an issue. the parts don't get scrapped...the hulls do. every time somebody buys a TRS boat, somebody else just sold it. net gain in boats potentially needing these parts is 0. you don't hear of very many people closing up their bravo hole in the transom and cutting it out for SSM or TRS. the real advantage of bravo over these other drives is the cockpit of the boat is 14 inches longer. and that matters more to most boaters than 90 to 130 mph does.
dereknkathy is offline
Old 01-05-2015 | 06:02 AM
  #82
I have yet to see a manufacturer extend the cockpit of a model because it's a bravo boat. I must not understand what you're saying,
Unlimited jd is offline
Old 01-05-2015 | 06:28 AM
  #83
Full Force's Avatar
I think he means the bilge is longer (more space) wake up Jaime hahahha
Full Force is offline
Old 01-05-2015 | 06:50 AM
  #84
Most boats that have/had SSM or TRS, cigs, Fountains, apaches, etc, were built for them. Even when bravo equipped they kept the original layout . now, certain boats, like Baja's or small runabouts that debuted after the bravo was introduced , yes , can have bigger cockpits. That was the main reason for a shiftable outdrive. More room
MILD THUNDER is offline
Old 01-05-2015 | 01:00 PM
  #85
dockrocker's Avatar
So, what about the NXT drive? No love for it?
dockrocker is offline
Old 01-05-2015 | 01:18 PM
  #86
For the money, might as well go to 6's I'd think.
Old 01-05-2015 | 07:46 PM
  #87
3's and 3a's are 24.311 input to output, I'll have to look but 4's and 5's are 18.6 I think
roughly 5 13/16" shorter Jamie 4s and 5s vs 3 and 3a
adk61 is offline
Old 01-05-2015 | 08:02 PM
  #88
transmissions are the best way to go.. reliable, smooth shifting and they buffer the torque from the engine somewhat... my 1450s work really well
adk61 is offline
Old 01-05-2015 | 08:26 PM
  #89
phughes69's Avatar
Originally Posted by MILD THUNDER
There is absolutely no way in hell, that a SSM III, should be rated below and XR sportmaster!. Or a KAAMA better than a 3A, 4, 5....I'll give my ranking list lol
#1 Arneson
#2 M8
#3 SSM 6 dry sump
#4 SSM 6 wet sump
#5 SSM 3A/5
#6 SSM 4
#7 SSM 3
#8 Konrad
#9 Kaama
#10 Bravo XR Sportmaster
#11 TRS/SSM II
#12 Standard Bravo
#13 Alpha
Just my opinion!
Mild, What is the difference between a SSM 3 and 3A. I know the propshaft diameter is bigger on the 3a. I think the prop shaft on the 3 is 1 1/4.
Also from what I know the Kamma is rated for 600 HP and doesnt have the problems of a typical outdrive with gears so wouldnt that still put it above a SSM 3
#1 Arneson
#2 M8
#3 SSM 6 dry sump
#4 SSM 6 wet sump
#5 SSM 3A/5
#6 SSM 4
#7 Konrad
#8 Kaama
#9 SSM 3
#11 TRS/SSM II
#12 Standard Bravo
#13 Alpha
phughes69 is offline
Old 01-05-2015 | 09:06 PM
  #90
J-Bonz's Avatar
Originally Posted by 88bullet
Where does a Volvo drive or OMC come into play???
Yeah, no love for the cobra or stringer drive....
J-Bonz is offline
