Top Swivel pin on aTRS >
Old 02-10-2015 | 06:16 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Default Top Swivel pin on aTRS
I see how you loosen the U bolt and that frees the pin up at the Gimble.You loosen the bolt that is thru the tiller arm.You take the nut off that's threaded on the tiller arm pin But NOW is that grease fitting .n the top of that pin threaded into that swivel pin.and the whole works goes out thru the gimble ring together.???????I'm little confused.
Fenderjack is offline
Old 02-11-2015 | 01:05 AM
You remove the grease fitting which is threaded into the top end of the swivel pin. Then take a pin punch and drive the swivel pin down/out. This is on page 4A-19 in the TRS manual #5. Did I send you that manual a while back?
That pin the tiller arm is on IS the swivel pin.
picklenjim is offline
Old 02-11-2015 | 07:51 AM
Fenderjack's Avatar
Yeah you did but as of yet have not been able to open the link
Old 02-11-2015 | 01:24 PM
PM me your email address and I'll send it to you again. Just test sent it to another one of my email address's and it worked fine.
Old 02-11-2015 | 02:58 PM
Fenderjack's Avatar
Did get the top pin out.with out a problem along with the bottom one.Question The swivel pi in the bellhousing threads in a little loose on one side will red locktight take care of that.
Old 02-12-2015 | 03:24 AM
I would say yes if the treads are good enough to hold the recommended torque of 60 ft. lbs. May want to use green Loctite 609. http://www.midwayusa.com/product/667...compound-10-ml Really good stuff I've used before!
Old 02-13-2015 | 09:15 AM
Fenderjack's Avatar
Has anyone ever heli coiled the gimbel pin holes,seems that would work.Where is a good place to buy the seals for the swivel pins.I have new roller bearings.
Old 02-13-2015 | 08:21 PM
I've done that a few times and also on bravos too.
sutphen 30 is offline
