Hard to get on plane-NXTs >
Old 09-09-2015 | 03:59 PM
I have a 38 top gun with high x that I been having the same problem . turning in is better but lost 3-4 mph . now turning out. I wind it up to 4500 rpm until it reaches 20mph then I back off throttles to 3000 rpm it catches. then quickly accelerate and it gets right on plane .if its rough out I have to go with the following sea. then turn back once on plane. bravo style 6 blade herings
47 lightning is offline
Old 09-10-2015 | 11:20 AM
hullofjustis's Avatar
Originally Posted by mad props
the props are satin finish 5 blade cleavers.
I do use tabs about half down. More makes it worse. I will try the little push method this weekend. If i can have stiff wind at my back it helps quite a bit.
I am tempted to install prop aerators i would just hate to make it possibly worse.
i don't think the aerators are going to help. I had to put a 1 inch spacer on my drives just to use the following see method. I have been able to get on plane using the satin finish 4 blades much easier than using the polished 5 blades.
Mine will not get on plane at all with the tabs down. Have you tried pulling them up?
hullofjustis is offline
Old 09-10-2015 | 11:48 AM
F-2 Speedy's Avatar
Try the tabs neutral, first time I had mine out the tabs were 1/3 down and the props would blow out, so I set them in the neutral position and it came up, nosed over like butta
F-2 Speedy is online now
Old 09-14-2015 | 06:00 PM
I was out at the SCOPE poker run this weekend in San Diego and tried a few things recommended here and so far patience is the only thing working lol. But I did have an awesome time boating down there.
Mad Props is offline
