Outdrive
Old 08-31-2015 | 08:21 PM
bblythe's Avatar
Default Outdrive
[attach=config]544786[[attach=config]544786[[attach=config]544786[/attach]/attach]
What.is the cable.for
bblythe is offline
Old 08-31-2015 | 08:23 PM
bblythe's Avatar
I am thinking ground for methbodes ?
bblythe is offline
Old 08-31-2015 | 08:25 PM
bblythe's Avatar
[ATTACH=CONFIG]544787[/ATTACH] broke one
bblythe is offline
Old 08-31-2015 | 08:48 PM
glassdave's Avatar
Neno the mind boggler
yep that links it into the mercathode system, ground strap I guess you'd call it . . . .
08 OPA High Points Champion
glassdave is offline
Old 09-01-2015 | 01:27 AM
Yep, mercathode wire and not really a big deal in fresh water.
Griff is offline
Old 09-05-2015 | 06:25 PM
Ayuh,..... I believe it's called a continuity cable, which is part of the bondin' system, which is necessary to limit corrosion of the pieces,....
Mercathode or not, it helps with electrolysis,......
Boats, All boats use a bondin' system, which ties together All it's metal pieces exposed to water, to act as a single piece of metal,....
Bondo is offline
