Trs upper With a Bravo Lower >
Old 03-27-2016 | 07:39 PM
  #61
Got her done and will be back in the boat in a week or so to start pounding on the drive again
SlowRyd is offline
Old 03-27-2016 | 10:52 PM
  #62
Motor numbers look great! This should give you little extra giddy up.
goin70 is offline
Old 03-28-2016 | 08:40 AM
  #63
Absolutely, should test the drive too
TruxtonFox is offline
Old 03-28-2016 | 09:01 AM
  #64
northernoffshore's Avatar
why hasn't Imco built a case like this ..... trs lowers are getting harder to come by
northernoffshore is offline
Old 04-09-2016 | 08:00 AM
  #65
Update. Got her in the water yesterday everything went great with the new power. The outdrive performed flawlessly. She handles way better than ever before. I've got one issue to work out before I can air it out though. For some reason with the new motor and 30p prop the transmission will not hold under heavy load. It holds if you ease in to it but it cuts loose when I try to bury the throttle. Gonna put a pressure gauge on it this weekend and see what's going on before I pull it out and see what kind of mods I can make to it. All in all I'm pretty damn happy with it and pretty sure triple digits are in the near future
SlowRyd is offline
Old 04-12-2016 | 02:40 PM
  #66
Great news about the improvements in handling. What rpm are you looking to turn? At about what RPM does the transmission slip? I will be interested to hear your next steps. Good luck and please keep us posted.
goin70 is offline
Old 04-12-2016 | 03:54 PM
  #67
I'm looking to turn it 5800 to 6000. It's has started slipping at anything much over 4500 rpm. And when I say slip I mean it let's go completely. If I back of the throttle it'll hook back up
SlowRyd is offline
Old 04-26-2016 | 10:19 AM
  #68
A little cruising vid with the top up running 45 https://m.facebook.com/story.php?sto...00002588868761
Also rebuilt my trans with a few mods aswell and ready to go back in the boat.
SlowRyd is offline
Old 04-26-2016 | 11:15 AM
  #69
what shaft did you use to connect the bravo lower with trs up? Or did you just use the stock shaft and cut new splines on one end?
turbom700 is offline
Old 04-26-2016 | 11:29 AM
  #70
I was able to use the stock shaft as a platform but there is more to it than just recutting splines
SlowRyd is offline
