Rattle Noise in Bravo1
Did someone that specializes in Bravo drives do the repair this time?
I find it hard to believe that lack of proper torque would cause that to happen.
The only way that could happen is if something were missing or something were installed in the wrong order.
Unless this time it was serviced by a drive expert I wouldn't run it until it is.
Update...They found a inner washer that looks like it was rubbing against something.. see pics... Probably from over tight pre-load adjustment and/or as stated before no torque wrench used only the spanner tool and a hammer. Putting drive back on tomorrow and start up. Hopefully noise gone..
[ATTACH=CONFIG]566810[/ATTACH][ATTACH=CONFIG]566811[/ATTACH][ATTACH=CONFIG]566812[/ATTACH][ATTACH=CONFIG]566813[/ATTACH]
The pinion can wiggle around, from the load being applied to it, the washer isn't compressed any more and is free to spin, further amplifying the issue.
Good question..This washer is located between the 2 bearings that are pressed onto the gear and the seal at the other end. It is considered a inner washer No metal filings were seen in the carrier and the input shaft and components, bearings, spacers were disassembled inspected and cleaned before re-assembly. I use Amsoil marine gear lube that is a clear drive oil..After draining the drive and removing the magnets nothing was seen. That washer has a groove in it when new. It only ran for 10 minutes at idle..It probably would have been worse under load
That wear is the byproduct of the pinion bearings losing their preload, seen it many times, that washer goes between the input yoke and the front pinion bearing cone, once the preload starts to go,
Thanks I will relay this
u-joint replacement) and not ran for a very long time, no less, not under load....my guess is that washer wasn't replaced.
If they did put the washer on backwards that would explain a lot of things...the washer is stepped, the step goes inside of the bearing, you flip that around, the shaft won't be able to go in as far as it should....probably not even far enough to get to the elastic part of the nut.
interesting he probably had the beveled washer in wrong
I found this to be helpful also
https://www.youtube.com/watch?v=c0SlzpJBhEM&t=467s
NEW UPDATE....SAME PROBLEM...Took the boat out for a short ride last weekend...Prior to that I decided to change the complete input shaft just to be sure...Re set the rolling pre-load with the drive oil on bearings to 6 inch lbs..Book says 3 to 7 used bearings...Used a torque wrench as the manual says to, tighten spanner nut...Torque wrench set for 120 @ 18" long with merc spanner tool @ 12" long gives you a torque of 200 ft lbs.Put drive back on boat. Started her up nice and quiet... As previously stated went for a 1 hour ride.. Kept rpm's under 4000...NO issues.. Got back to the marina put the boat back on the trailer. I always rinse my motors, Started her up and that same rattle noise was back 2 fold....Louder than ever.. We install another new seal, lock nut and red locktite. How can it be loosing preload???
Need help Please???
Need help Please???
