Rattle Noise in Bravo1
Hi, I found a lot of drive oil inside my bellows so i brought my drive to a merc mechanic. He said it was the seal and he replaced it. He also replaced the u joints since the drive was off the boat anyway. Yesterday i started the boat up on a hose and noticed a rattling sound that i never heard before coming from the upper housing area. After doing some research i noticed that there is a procedure to adjust the rolling preload on the bearings.. If the preload was incorrect can it make a noise like this?
what else could it be?
note. Drive is spinning in gear looks like it is just rocking back and fourth..not the case just shows that way in video
https://www.youtube.com/watch?v=au6xujfCaOk
https://www.youtube.com/watch?v=jWcaYPjrQBU
Something is wrong inside the drive. The U joints wouldn't make any noise with the drive level to the hull.
You did refill the drive with oil right.
If the noise gets louder when you turn the drive it is probably because you are side loading the input shaft.
I bet the input shaft bearings are bad.
My drive has an OF starting part of the serial#. It is back from 2003 year I believe 2nd gen. How do you know if the input shaft bearing pre-load is 5lbs rolling or just tighten to 80 lbs torque..Is there a way of telling?
