Imco sc stronger then a built bravo?
The IMCO SC has a much stronger case, has a much stronger cap- (stainless steel vs Aluminum and 8 bolts holding it down vs 4), The tower is longer than most tower inserts and tolerances are tighter, at least the ones that I've built were. Is it 2x's as strong? No, but pick up an XR case and then pick up an IMCO case. There is no comparison as to which one has more material in it. Yes the gears, shafts, bearings are all the same, but if the case flexes less which one will hold up better? Not to mention, how much are these other guys charging for an improved tower? Other than that what can they really do to make a stock case better?
I've replaced broken prop shafts, vertical shafts, clutch shafts and a couple of lower gear sets, but the things I replace most often are the upper gear sets, which are no different between the two.... these things just don't have that long of a life span....you can't upgrade a SC to a SCX....if that were the case, you would have folks stuffing SCX gears into XR cases
