Drive spacer install question - loctite >
Old 01-27-2018 | 11:26 AM
Default Drive spacer install question - loctite
hey all, I’m installing a spacer in the drive. The directions that came with said use loctite 272. I can only find 271 locally. I’d really like to get it installed tomorrow (for many reasons) so don’t really have time to order 272. Can 271 be used? Or should I just try to figure out how/when to install it after I order 272? Help please. Thanks!
asadler101 is offline
Old 01-27-2018 | 01:28 PM
What drive and what do they want loctite on?
class6 is offline
Old 01-27-2018 | 02:38 PM
Bravo 1, on the longer studs I have to install
Old 01-28-2018 | 01:55 AM
The 271 will be fine. Its virtually the same as 272 according to the specs. Both are red and heated to get apart.
That being said, I never used any loctite on my studs with a drive spacer and never had any issues.
Personally, the most I'd use is some blue loctite, I think its 242???
Griff is offline
Old 01-28-2018 | 09:16 AM
Never used any. I replace the nylocks after 2 times on and off
class6 is offline
Old 01-28-2018 | 01:02 PM
Thanks guys!
Old 02-12-2018 | 12:21 PM
This stuff works on anything.. A little on the threads acts as mild locktite and also works as an anti-seize. Works Particularly well on Exhaust Riser studs or bolts.
https://www.westmarine.com/buy/perma...SABEgIV7vD_BwE
Chris
Blueabyss is offline
Old 02-14-2018 | 11:34 PM
Mr Gadgets's Avatar
Charter Member #601
I generally use the red loctite on the threads screwed into the case to keep it from unscrewing when I remove the nyloc nuts. If I had a problem removing the studs I use a MAP torch to warm them up and with a stud puller they come right out. I have removed at least a hundred of them..
Hope that helps.
Dick
Mr Gadgets is offline
