Blew up XR ITS Upper
#31
No it can be done, by rotating the lower 10 times, then divide by 10. Your rotating 10X because it becomes more obvious, then working with small degrees
As example
Upper gears 19/16 = 1.187
Lower gears 15/19 = 0.789
Calculation 1.187/0.789 = 1.504 ratio
So rotate and count
1.26 lower 17/18 = 0.944 10X = 9.44
1.35 lower 15/17 = 0.882 10X = 8.82
1.50 lower 15/19 = 0.789 10X = 7.89
As example
So rotate and count
#35
That sucks. I broke a tooth off the gear set and locked up the drive. Where your splines are twisted on the short shaft, mine sheared of clean off. It didn't damage the case though. I have an extra long shaft if you need one. Man, I don't miss I/O's.
You're going to need a bigger slide hammer! Those splines are impressive.
