XR advise
#33
When rebuilding our drives I went back and forth on helical vs. xr...granted we don’t have huge power, because we are running a 11,000 lb top gun I went for the xr’s.
I dont have much much experience with the helical but from research they work better in small power small boat applications. It’s a matter of what you think you can get away with.
When I saw this picture, it re confirmed my decision.
#34
On yours did you have a standard Bravo drive? I ask because those don't have steel towers and are 1" shaft. If that upper flexes a little the non steel tower breaks and you are done. Case flex is a reason a lot of drives fail,,,,,, and why a IMCO SC has XR internals but a stronger case.
When you take a XR drive and put XZ gears in you get the strong steel tower, larger shaft etc but go back to the gear that doesn't pit.
George has said he was going to make XR gears, that would help a lot. If he ever gets around to it.
Or SCX for bigger power.
#35
Drove to Michigan Thursday and picked up the drive at AADS. It took a little longer then initially thought as Merc was slow shipping some bearings. We went with the XZ gears and George's top cap and tower. Also had him install a shower. My marina installed it Friday and we put it in Saturday morning. So far all is good but still in the break in period. Easy starts, vary the speeds and do not exceed 75% power.
Padraig
Padraig
#36
I do understand your reasoning here and hopefully you will end up with a better drive. I just made my decision based on the fact that my drives were 10 years old, had 340 hours on them and I had no way to know if the cases and main shafts were in good to go condition. AADS has a good rep on here and I have no doubt they do fine work, just did what I felt was right for me at the time.
#37
Thanks Ragged! I sometimes think it a crap shoot. Hopefully I have a good strong drive. Time we tell . I now have about 5 hours on it and still breaking it in. Will be attending the Battleship Run on Seneca Lake this weekend but will be still taking it easy. Back of the pack for me, LOL.
Padraig
Padraig
#38
Padraig
Padraig
Hopefully I can pick up my repaired exhaust tip in the morning and get this Biotch in the water this weekend. I need a boat ride!
#40
Dropped off mine about a week or so ago, at AADS now getting the Mod phase 4.
2 year warranty, and George comes very highly recommended. (From Joel at Action water sports. Whom I have had VERY good luck with.)
I sure hope its nice out this year in Sept. lol
