IMCO SCX vs Arneson >
IMCO SCX vs Arneson
IMCO SCX vs Arneson
Old 09-27-2019 | 12:43 PM
Originally Posted by ICDEDPPL
Getting parts and support thru Arneson is going to be a problem. 1 star
I've heard this a lot -- what specifically happened to you just long delays on parts?
PantyDropper is offline
Old 09-27-2019 | 05:35 PM
I never had problems getting parts from Arneson , although my list was small , bearings ,seals ,studs and the big castle nuts that hold the thrust tube on .
green lightning is offline
Old 09-29-2019 | 03:34 PM
From: Palm Beach County, Fl. ( formally N. California)
Uh,....... WHEN was it you didn't have problems getting parts from Arneson*** / Rik ?
*** In Name only... Howard has nothing to do with his custom drives anymore...... He handed the business on a silver platter to Rik about 10 years ago. ( From what I hear, Rik has not done Howard any favors in respect to the namesake since then )
And that pisses me off....
mountie is offline
Old 09-30-2019 | 07:40 AM
I have personally bought parts from Rik on multiple times over the last 4 years , this is the length of time I have run a set of ASD7's on my boat .This is my personal experience not something I heard ,
Old 09-30-2019 | 08:35 AM
What typically do you need to buy parts wise/what have you seen fail over 4 years on the drives? What kinds of costs?
Old 09-30-2019 | 09:24 AM
I bought my drives used and the boots that go over the ball on the thrust were ripped so I wanted to replace them. When the thrust tubes were apart ,I replaced seals ,castle nuts, bearings , boots, and (2) broken studs. I don't remember the cost I will have to find the receipts the only thing I thought was costly was the castle nuts that hold the thrust tube on . In the 4 years I have ran these drives nothing has broken with the drives something I could not say when I was running bravos .
Old 09-30-2019 | 02:10 PM
Please do me a favor???? Edit OUT my unfair comment about Rik and his surface drive business.....in your post if possible?? My comment was uncalled for and totally ignorant of the facts.
I observed Rik's 125% effort at the old shop. ( I was totally confused about the rumors about Rik - It made no sense to me )
DO NOT BELIEVE the negative comments being spread around about Rik........ He is a master building the Arneson drives, and there are some fake news from others.
Thank you
mountie is offline
Old 09-30-2019 | 02:51 PM
Thank you
Why would you state something yesterday and then do a total 180 today? Doesn't make a lot of sense??
Old 09-30-2019 | 02:55 PM
I was reacting to what I heard for a while...... I since found out the truth. 180 degree turn.
mountie is offline
Old 09-30-2019 | 04:18 PM
Quinlan's Avatar
Originally Posted by MAXIMUSXXX
Quinlan,
what lowers are you running? I have a TG with 750’s running SCX’s with SC lowers. Had to replace lower gear set after half a season. I was told prop free spinning was the issue. Basically, getting a little air and reentry into water. I’m very aware of it, so was surprised with they failed. I run in the Gulf of Mexico, so there’s always odd rollers that sneak up on ya.
I have SCX upper and lowers. They do scrub some speed- But not near as much as Broken Chit does
Quinlan is offline
