Drive guardians
Old 11-08-2020 | 03:54 PM
  #31
Originally Posted by ICDEDPPL
All fuzz and breakage stopped when I upgraded to #5`s and Amsoil gear oil.
I should have spent my money into that improvement instead .
What lube were you using before the switch to Amsoil? Did you change the drives when you started using Amsoil? Wondering if it is worth switching. I have twin Yanmar Diesels with X diesel drives. I (BAM Marine) rebuilt them at almost 1000 hours because I had pitting in the upper gears. I almost never leave the water but do run hard occasionally and often do runs to Bahamas with a lot of weight on the boat.
pstorti is offline
Old 11-11-2020 | 06:55 AM
  #32
You got a 1000hrs???? I think I'd stick with whatever the heck you were doing!
jmoore1225 is offline
Old 11-17-2020 | 07:43 PM
  #33
lol the engines are only 315 hp, well about 375 now after some fiddling, but still low compared to most on here. The do have a lot of torque and the way diesels make power is supposed to be hard on drives. But since I don’t like throwing money away I try to be easy on them when I can.
the have mostly had only Mercury HP gear lube. But maybe you have a point. If it ain’t broke.
pstorti is offline
Old 11-18-2020 | 06:39 PM
  #34
If anyone's interested I'll sell mine.
Mike rebuilt them for me and I believe there set for 725hp. Still in the boxes.
Both for $3000 plus shipping
outlw36 is offline
Old 11-18-2020 | 08:10 PM
  #35
Are you going back to standard couplers?
Unlimited jd is offline
Old 11-18-2020 | 08:15 PM
  #36
I had one clutch set to low and when it burnt up I switched back until they were repaired but never got around to putting them back in. Since going to scx uppers haven't had any issues.
outlw36 is offline
