Bravo 3 - Overheating ? Long Island
#31
As before $200 for a piece of SS tubing was my only issue and I bought it some years ago
It must be worth it because I bought one, but was on the fence with the drill type. Thought about making one my self, just don't have a TIG welder
#32
Not a band-aid fix. Heat is the biggest problem with anything that has oil, gears and bearings. If you keep the oil cooler, it will lubricate better. Does your outdrive get that white chalky buildup on it? Oil smell burnt and is black? When oil gets to the temperature of about 304 degrees it starts to break down. You know what happens not long after that.
your drive shower won’t fix bad pre load, bad bearings, or bad gear sets.
