Exhaust block off plate >
Old 03-04-2021 | 06:26 PM
Originally Posted by SB
I believe so. It wasn’t 4”. A 2” fit on the Alpha drive inlet. I remember that lol. The boats are here, but wrapped for winter. We are driving our trucks and sleds on the lake right now, not boats. Lol
well, we are in the the tail end of comfortable boating season...lol
38fountained is offline
Old 03-04-2021 | 09:17 PM
rubber pipe cap with hose clamp...maybe put some bellows adhesive on to seal it in.
1MOSES1 is offline
Old 03-04-2021 | 11:08 PM
Looks good...
Old 03-05-2021 | 05:11 AM
There’s 2 holes exiting a bravo transom assembly at the 4 and 7 o’clock positions that lead to the exhaust port. You would have to seal those off also.
Unlimited jd is offline
Old 03-05-2021 | 06:59 AM
That's what zi thought, thanks for that, Do you think spray foam would work???
Old 03-05-2021 | 07:21 AM
SB
Bummer about the two holes.Never had to go in that far with my bravo from years ago. Just drive replacement few times. Doh ! Finally found a pic. You should be able to click and expand.
SB is offline
Old 03-10-2021 | 03:25 PM
New discovery....... when I attempted to raise the drives, the leaky side blew out large gobs of oil straight from hydraulic lines. Lines are intact. Suspect a major problem with the hydraulic Manifold at the bottom of the gimbal housing. Any similar experiences or thoughts?
Old 03-10-2021 | 10:27 PM
I suppose the manifold could be leaking...more likely leaking from the crimp on the hydraulic hose or the tube cracked off the fitting. Atleast that’s what happened on our fastech 292.
1MOSES1 is offline
Old 03-21-2021 | 09:50 AM
Same thing happened to me last year. The manifold rotted, and the hose blew off. Not a terrible fix. Change the mercathode while you are there. It has to come off anyway
kdratch is offline
