Bravo 3 ratio
Old 05-20-2021 | 12:27 PM
Default Bravo 3 ratio
After inspection of my bravo 3 upper. The forward gear is gone.
I have the chance to buy a good bravo 1 upper cheap from a friend.
it’s a 1.50 though so will give me 2.0.
my leg is 1.81 now and I run 26p props.
I have spare 28p props would that keep me around similar?
Seanyb82 is offline
Old 05-20-2021 | 02:03 PM
That should be pretty close, you’ll definitely notice better acceleration
JaayTeee is offline
Old 05-20-2021 | 02:20 PM
do you think I’ll lose much top speed. It’s a forums 271. I was seeing 65gps with 1:81 and 26p
Seanyb82 is offline
Old 05-20-2021 | 07:42 PM
What was the RPM you were turning at wot?
if you were in the lower range of the band, you should be fine, if you were at the upper end, you could be on the rev limiter with the new gearing
that would be the only way you loose speed, then you just change to the next larger size to get it back.
I suscribe to the theory that it’s better to run a higher reduction and turn a larger prop slower than a smaller prop faster( with a lower reduction)
JaayTeee is offline
Old 05-20-2021 | 07:49 PM
So the original was a 1.65 right?
I think the 1.65 was common in Bravo 3.
Keith Atlanta is offline
Old 05-20-2021 | 07:58 PM
He had a 1.81 b3 which is the same upper as a 1.36 b1
the 2.2 b3 is a 1.65 b1 upper
JaayTeee is offline
Old 05-20-2021 | 09:49 PM
If you want to sell your 26 props I’m interested
flat rate is offline
Old 05-21-2021 | 12:56 AM
with the 1:81 and 26p I was around 5200rpm wot. Rev limiter is 5500rpm. It’s a built 502
Seanyb82 is offline
Old 05-21-2021 | 08:36 PM
I think you’ll be ok
JaayTeee is offline
