Bravo xr- imco sc- imco Scx >
Old 07-27-2021 | 03:08 PM
bencini231's Avatar
Originally Posted by spending money
Well the upper is trashed and metal was sent throughout.
guess it’s decision time now. Looking at like about 18k for a new upper sending the lower to imco for rebuild and a few other parts (helmet, drive reservoir and adaptor for the steering)
that’s probably the same as rebuilding and then Buying a spare
I just bought 2 SCX upper conversions from Fred @ Imco. Your correct on the Helmet, drive reservoir and the steering cap comes with the drive. You'll need the SC/SCX Coupler as well.
bencini231 is offline
Old 07-27-2021 | 05:10 PM
Veteran: Coast Guard
Just spoke to Brad at imco. They make a shaft that fits the scx upper without an adapter. The lower will go back for a rebuild anyway. If that’s the case and the shaft is trashed then I can just get the correct shaft.
At the cost of a rebuild for xr and the sc lower. One more explosion and I could have had a scx. I can keep justifying it but damn it sucks pulling the trigger.
spending money is offline
Old 07-27-2021 | 05:11 PM
Old 07-28-2021 | 06:05 AM
Quinlan's Avatar
Glad you are going there sooner than later. It took me about 8 rebuilds before I GOT it lol
Quinlan is offline
Old 07-28-2021 | 06:14 AM
The new shaft for the lower is needed to use a spacer.
IMCO has their adapter coupler for standard length.
RedBoatFl is offline
Old 07-28-2021 | 07:00 AM
Spending Money,
Have you spoken to George at All American Drive Service in Michigan?
Thanks. Brad.
Model Machine and Precision LLC
(937)545-8991
Brad Christy is offline
Old 07-28-2021 | 10:11 AM
Spending Money,
Thanks. Brad.
(937)545-8991
I have not yet.
having the lower sent out to imco for a rebuild. Still deciding on if the scx is the way to go or if it’s overkill.
I don’t believe that the boat is making over 700hp and weight is probably around 4500 pounds. What’s realistic. Do I bite the bullet and just do the scx and not look back?
Old 07-28-2021 | 10:24 AM
i have not yet.
Having the lower sent out to imco for a rebuild. Still deciding on if the scx is the way to go or if it’s overkill.
I don’t believe that the boat is making over 700hp and weight is probably around 4500 pounds. What’s realistic. do i bite the bullet and just do the scx and not look back?
Hell yes!
cheech is offline
Old 07-28-2021 | 10:25 AM
I have not yet.
Spending Money,
I spoke with him at length about a custom drive for my PowerQuest 280. I'm running a 496HO with an M1 ProCharger through a stock B1. That's approx 615HP through a drive rated at 425 in a 4800lb boat. Fortunately, the ProCharger really doesn't kick in any real benefits until the boat is well on a plane and running pretty light. I've also been staying off the fun stick until I can talk the wife into the drive swap, which is frustrating, but saves on repair bills. George explained, in greater detail than I needed or could consume, that he could build a custom drive that would withstand our application for 500+ hrs. I'm sure he could probably do the same for yours for WAY less than you're chewing on. Just a thought.
Thanks. Brad.
(937)545-8991
Old 07-28-2021 | 12:58 PM
Well it’s done. Sending a check as a deposit tomorrow for the scx. The sc lower is on its way to imco now.
