Arneson Surface Drives ASD10 >
Old 10-03-2022 | 12:14 PM
ricardo mann's Avatar
Default Arneson Surface Drives ASD10
PHi
I wonder if anyone can help me?
I have a powerboat with two ASD10’s. The reservoir on one of them is filling up with emulsified oil. I am told that new bellows were fitted around 2 months ago and having taken her out of the water these do appear to be new.
I believe that there are two seals on the prop shaft, one being a water seal and one being an oil seal.
My question is, can these seals be replaced without removing the casing from the driveshaft and ball?
I’d appreciate any advice/thoughts
Ricardo
ricardo mann is offline
Old 10-04-2022 | 07:27 AM
KNOT-RIGHT's Avatar
Dana Birkland however he may have retired this number may still be active.
262-631-9773 Twin disk
Twin Disc has all the parts and even the diagrams
KNOT-RIGHT is offline
Old 10-04-2022 | 10:09 AM
Here is a link to the service manual for the asd15..may help for a reference to the internal layout. The online manual has a active table of content to click on navigate quicker through the manual
https://manualzz.com/doc/6292883/ser...al-arneson#p14
speicher lane is offline
Old 10-04-2022 | 11:56 AM
Thanks to all for quick reply
Old 10-06-2022 | 05:03 PM
Yes, they can but more likely to be the gland packing ring that seals the ball, give me a call sometime and I will run you through the process.
Jason
999JAY is offline
Old 11-10-2022 | 08:03 AM
Prop shafts are any easy replace and probably the best place to start. The seals should be in a bronze "block" that rests just inside the housing where the shaft exits. The block should have three threaded holes (metric). You will need three screws to insert to
act as a puller. Somewhere on the outside of thrust tube about 1" from the tail end will be two (i think) set screws that thread thru the thrust tube and rest against the seal block to secure it. Remove prop, remove set screws, insert three screws and tap on them to remove seal block.
Insert two new seals (opposing) and reverese.
As far as the ball socket being the cause, I think you would see some milky mess inside the boot if that were the case. But you can pull the boot back and snug up the retainer ring pretty easy. I would receommend that.
We just finished a rebuild on a set of ASD #8. With some pics if u want to see
pizzacuttter is offline
Old 01-21-2023 | 01:01 PM
Nice to see a few Arnesons left, I only have baby ones, ASD6 a chain drive and counter rotation gear drive unit, 1.31 and 1.33 if memory serves. Believe it or not, the Arnesons and about 650 hp per side pushed my 30' Cobalt beyond its limit on longitudinal stability, only could turn 4400 RPM before my bravery failed me. Hooking and resulting brown shorts was not acceptable.
HEMTT is offline
