Go Back  Offshoreonly.com > Technical > Electronics
Dash mounted warning lights >
Old 03-06-2023 | 01:36 PM
Griff, Do you know if all of these run on a common wire to the dash? I only have 2 warning buzzers at the dash. I have heard them go off for overheating and also the drive oil.
PQ290Enticer is offline
Old 03-06-2023 | 08:49 PM
Same wire. Not sure exactly where they connect to each other before that. Somewhere in the engine harness. All the alarm wires are tan with a blue stripe and all of the alarm sensors are completely separate from the gauge sensors.
Griff is offline
Old 03-08-2023 | 09:03 AM
Mbam's Avatar
Offshoreonly Advertiser
Unless they are the old school Mercury buzzers that have a timer they should also sound whenever the ignition is on and the engine is not running -
no oil pressure.
The timer was about 10 seconds if I remember correctly.
Mbam is offline
Old 03-08-2023 | 02:13 PM
They do sound off if I turn the key to "on" but not start. They may shut off automatically but I can't stand the noise and never waited that long. I had one sound off for the drive oil. That took a little while for me to figure out because my last boat didn't have that reservoir. Thanks for the help.
Old 04-08-2023 | 11:47 PM
I made this before I had Holley guardian mode
I bet it`s still somewhere around here , they were bright leds.
ICDEDPPL is offline
Old 04-09-2023 | 09:31 PM
Love this. What is Holley guardian? Google turns up nothing and my manual has nothing on it, either. Would love to utilize that first before building out my own lights
CheckmateScarab is offline
Old 04-14-2023 | 11:21 PM
Rookie's Avatar
I believe Dan is referring to his Holley EFI system to trigger warning lights to his digital dash when his sensors fall out of the tolerances he set. And also put his system into a limp mode by pulling timing, cutting cylinders out or adding additional fuel to save a failure.
Rookie is offline
Old 07-05-2023 | 04:22 PM
If you stumble across your panel again send me a PM. if your willing to let it go.
tomcei is offline
