Go Back  Offshoreonly.com > Owners Forum > Eliminator
27 Daytons w/IMCO extension Box >
Old 01-08-2011 | 10:12 AM
Cat-n-Around's Avatar
Default 27 Daytons w/IMCO extension Box
Considering adding an IMCO extension Box to my 07 27 Daytona ICC. Has anyone had any experience with them do they help or is it even worth it? I have 900hp motor 2" Shorty but I had to install a 1" spacer to help get the boat on plane..
Cat-n-Around is offline
Old 01-30-2011 | 01:44 PM
Question
Just my opinion, but from what ive been told and read over the years on IMCO ext boxes, they arent met to help the Cat up on plane,, and really not necessary on single I/O cats... I asked an Eliminator rigger this question years back for a 25 Cat, and he told me to "save my money", I didnt need it....From what im told, the IMCO ext box sets the prop back allowing you to pick up "top end speed" due to the prop being pushed back "into calmer, less distrubed water", but had nothing to do with the Cat getting up onto plane..... idk?
Plus, it was a very expensive proccess,,, so make sure you wanna do it first......
It does look good "cosmetically" and looks blingy,,, but is it worth all that work/money? .. idk
the plane problem seems like a drive issue,, the lower skag to high, or the drive mounted too high.... or the pitch on the prop may need to be lowered... idk
anyone?
PokerRun388 is offline
Old 01-30-2011 | 08:27 PM
Turbojack's Avatar
Where is your prop shaft compared to the outside sponsons? I have a standoff box, prop is 1/2" above sponson and have no problem getting on plane.
Turbojack is offline
Old 01-31-2011 | 01:11 PM
Default Imco
My 28 has them. Some pictures
27 Daytons w/IMCO extension Box-2161214_19.jpg
ElimiNordic is offline
Old 02-03-2011 | 08:15 PM
Im 1/2 below the sponson.
Old 02-04-2011 | 08:11 AM
Turbojack's Avatar
As I have stated I have no problem getting going & my prop is 1" higher. When I run a bravo 4 bade, unless I am runnin over 35 the boat will slow down with motor keeping same speed. When I have 5 blade on, no problem anywhere
Old 02-04-2011 | 03:14 PM
Thats with a box and 2" shorty?
Old 02-05-2011 | 08:13 AM
Turbojack's Avatar
yep
Old 02-05-2011 | 10:34 AM
Question
Save your money.....Its not gonna help you get onto plane...
you have other issues.... IMCO standoff box NOT the solution.
