how to clean rub rail????
Re: how to clean rub rail????
Originally Posted by US1 Fountain
Used the acetone on my old rubrail insert with fair results. Don't soak the rag, just damp, then work fast. Soaking it will make the insert soft. Try to keep off the molding. But I did use a rag at times heavy with acetone to rub out scratches in the molding. It softens the plastic enough that you can rub across the scratches until it 'melts' smooth. I did notice that the insert got dirtier faster and easier and lost the shine after using acetone. Ended up replacing the insert with a new one and no longer use acetone. Black streak remover or bleach white only now.
Originally Posted by offthefront
I think Acetone ....someone will chime in ....but ONLY on the rubrail ....
BINGO
2014 OPA-APBA National Champion Class 7 .Hauling Trash 725.
Originally Posted by G Man
What happens if you get acetone on gel coat???
I've used fine sandpaper and wetsanded it. I discovered this by trying to remove deep scrapes and chew marks from contact with pilings and big waves
Gary H...
Gary H...
Soft scrub on one of those scrubbing type of sponges works great.
