242 SS Mystery pump ??? >
Old 04-15-2005 | 08:19 PM
Default 242 SS Mystery pump ???
I recently bought a 1991 242 SS and am in the process of going through everything in preparation for the season. On the port side rear compartment where the battery switch is located, I notice a device that looks like a pump of some sort. It has been disconnected (wires cut) and appears to have been put out of service some time ago, but left in place. There are 2 wires and some clear flex hose hanging from the device. It does not seem to connect to anything else. I cannot see any markings.
The hydralic pumps are all in the engine compartment where they are supposed to be. So, I am wondering what this mystery device may be? Any 242 owners know for sure?
Thanks in advance,
TPenfield
1991 242 SS
tpenfield is offline
Old 04-15-2005 | 08:51 PM
RedDog382's Avatar
Default Re: 242 SS Mystery pump ???
Maybe a pump for the sump under the step in the cabin? Any pics?
RedDog382 is offline
Old 04-15-2005 | 09:32 PM
May have been a fresh water washdown for the transom/platform area. Any signs of a fitting on the transom?
ThirdBird is offline
Old 04-16-2005 | 02:40 AM
R-Don's Avatar
Hi Tpenfield,
I think you will find its the trim tab pump and by the sounds of it its been disconnected. Is the boat still fitted with trim tabs?
Do they work? If so, they must be working off a different pump. If not then you will want to get it fixed before the season.
Good choice of boat.
R-Don is offline
Old 04-16-2005 | 04:19 AM
Not the trim tab pump, because it has the Bennett pump in the engine compartment along with the outdrive pump. They all work fine. The tubing that is coming from the pump is 3/8" clear and of the low pressure variety.
Transom shower may be a possibility, but I do not see any evidence of a shower device around the transom.
It may be an after market device, but it sort of looks like it was meant to be there. Perhaps I will take it out for further investigation.
tpenfield
Old 04-16-2005 | 09:09 AM
PhantomChaos's Avatar
How big are the hoses, and about what size is the pump? I'm thinking an electric fuel pump to get gas out of the tank and into a jet ski?
PhantomChaos is offline
Old 04-16-2005 | 01:15 PM
R-Don's Avatar
I was thinking more of pumping the gas out of someone elses boat and in to your tank!
R-Don is offline
Old 04-17-2005 | 06:08 AM
I have 84 242 Ls w /twins the clear hose goes down to the v in the hull the one in my boat is the original bilge pump mine is rusty mess if was not such a tight spot i would replace it
bill1100 is offline
Old 04-17-2005 | 08:30 PM
toolman's Avatar
From: Pennington, NJ/Delaware river/Upper Chesapeake bay
Sounds like an air horn pump to me.
My 303 has an air horn pump located on the port side near the battery. 2 wires, positive and negative and the clear tubing should go to the horn itself.
Does your boat have a horn that works?
toolman is offline
Old 04-18-2005 | 11:50 AM
Now that's a good thought!! I bet you're right Toolman.
BOBCATMATHEWS
4
02-27-2012 04:16 AM
SeeYouThere
Sunsation
12
04-09-2009 09:10 PM
cooltoys61
6
07-28-2004 01:47 PM
klaw
5
04-07-2003 11:42 AM
