Engine room treadplate >
Old 12-19-2005 | 04:46 PM
RedDog382's Avatar
Default Engine room treadplate
Replacing the rubber mat on the step in my engine room with powdercoated aluminum treadplate. Rubber was looking pretty bad. Custom fabricated deal.
Before/after:
Attached Thumbnails Engine room treadplate-treadplate-006.jpg   Engine room treadplate-treadplate-001.jpg
RedDog382 is offline
Old 12-19-2005 | 04:48 PM
RedDog382's Avatar
Default Re: Engine room treadplate
Before/after:
Attached Thumbnails Engine room treadplate-treadplate-005.jpg   Engine room treadplate-treadplate-003.jpg
Old 12-19-2005 | 04:49 PM
RedDog382's Avatar
More:
Attached Thumbnails Engine room treadplate-treadplate-007.jpg   Engine room treadplate-treadplate-004.jpg
Old 12-19-2005 | 06:50 PM
Hey, did that save any weight?
Thanks,
Garrett
FormulaM2Formula is offline
Old 12-19-2005 | 07:51 PM
RedDog382's Avatar
Probably about the same weight as the rubber. I used the 1/16" treadbrite which is the same thickness as the rubber mat. It is actually a little flimsy, but it is secured to 3/4" plywood so I don't think it will matter. I would have preferred to use the 1/8" treadplate ... it is pretty stout but it is also a fair bit heavier.
Old 12-19-2005 | 09:41 PM
Garrett, if you decide to do that, you better show me some pics
Looks like it is going to be sweet Chris. I'm ready to see what it looks like installed
Corey
lonestar382 is offline
Old 12-19-2005 | 11:29 PM
Question Re: Engine room treadplate
Hi Corey,
I'll probably wait a little while on the mod's. I talked to Mike today. Sounds like the boat is running really great. Weather permitting, I'll be driving out to pick it up on the 27th and get the boat on the morning of the 28th. I think.
I bet that aluminum tread plate would look good anodized black. But, the powder coat is probably better at resisting corrosion, I'm guessing.
Garrett
Old 12-20-2005 | 06:01 AM
RedDog382's Avatar
Corey
It's out to the powdercoaters now. I will get a couple shots when I get it re-installed.
Old 12-20-2005 | 09:20 PM
mopower's Avatar
Toxic FORMULA
I don't have to worry about any rubber mats. I don't even have room to drop a wrench
mopower is offline
Old 12-22-2005 | 03:22 PM
RedDog382's Avatar
One day turn-around with my powdercoater:
Attached Thumbnails Engine room treadplate-treadplate-011.jpg   Engine room treadplate-treadplate-009.jpg   Engine room treadplate-treadplate-010.jpg
