Headliner problem/question >
Old 08-31-2006 | 08:24 PM
J.B. Marshall's Avatar
JB Marshall
Default Re: Headliner problem/question
Nothing yet and the way it has been handled thus far I doubt Formula will even respond. I have been greatly disappointed with Formula and in the way I was brushed off. I really gave them more credit than that, I guess to much. They could have provided some options for me to work with.
J.B. Marshall is offline
Old 09-05-2006 | 10:44 PM
I have read the all of the above resonses and wonder what other boat company has a lifetime unlimited warranty on interior headliners. The first question I would have asked is where the boat came from, Florida ,Huh well wonder if the 98.6 humidity and 6 years of baking sun had anything to do with this problem. You got a great boat, call Formula and order the headliner kit invite the guys over for a work party.
selpel is offline
Old 09-06-2006 | 11:45 AM
JB Marshall
So you say, all Formula boats out of Florida after five years should have this acceptable problem? I don't think so, not at the prices of these boats and or the quality that Formula boats are supposed to have.
So how many Fastechs have you replaced headliners in and what is a headliner kit? Formula never informed me of a Kit??
Old 09-06-2006 | 09:38 PM
NO! What I said is that in a used boat you have no way of knowing how it was stored season to season. Was it put away wet at some point? Did someone leave a side port hole open to the elements? There are a number of situations that may have happen and as a second owner you may not have the full store. I am willing to bet if you contact Formula tech service and ask about the material you will need to repair this problem they can cut and prep all the pieces you will need. And yes we have replaced a sagging headliner with parts from the factory.
selpel is offline
Old 09-06-2006 | 10:07 PM
To let you know the sagging headliners we replaced were caused by the owners NOT take care of their boats. Not because of faulty headliner material!
selpel is offline
Old 09-07-2006 | 01:41 PM
Spoke with my parts dept. today and they can get 90sq.ft. of headliner for around $8.69 per sq.ft= $782.10 plus shipping. This is the amount to completely replace your headliner. You will have to clean your panels before installing new material. It will also come in a roll and you will have to cut to fit.
selpel is offline
Old 11-26-2006 | 09:49 AM
PhantomChaos's Avatar
Is the headliner material at fault, or the foam, or a glue agent that holds the two together?
PhantomChaos is offline
Old 11-26-2006 | 03:41 PM
sneekinfreek's Avatar
most likely the glue . the adhesive can fail if under extreme heat and moisture. kind of like laminate counter top glue if you have a dishwasher that creates extreme heat and moisture the glue will fail and you will get a bubble that will form . The glue for counter tops and uppolstry are very simular and both react the same . you can buy this glue in spray cans at your local hardware store. another issue can be that the manufacturer did not applie enough glue or too much. so be generous with the glue but not to much where it looks like you blew snot on the material. the material is also available through a place called milliken. i believe this is who formula uses .
sneekinfreek is offline
Old 11-26-2006 | 04:08 PM
ninetym's Avatar
How can an owner missuse a headliner?? Temperture should not make a difference .. It should not fall down under any circumstance except flooding.
ninetym is offline
Old 11-26-2006 | 04:12 PM
ninetym's Avatar
I tried a search on milliken and couldnt fine any info on marine uses. Wonder if maybe you had a web address. Thanks mark
ninetym is offline
