Back In The Water Again!........ >
Old 08-26-2006 | 07:44 AM
K-MAN's Avatar
Default Back In The Water Again!........
Hey Folks,
Just purchased a 2001, 312 Fastech, "SUPER CLEAN" with
190 hours! The only problem I'm concerned with is the engines. 7.4(454) MPI's with Bravo One Drives. I know the
engines are not performance type that I have had in the past,
but more like workhorse engines, 310HP. Alot of room to play
with here. The drives have 4 blade 28 pitch props, would
like to know if I need to change these out to get a little more
punch out of the hole or just leave well enough alone? Any help and suggestions and what to look out for are appreciated.
K-Man
K-MAN is offline
Old 08-26-2006 | 10:09 AM
mopower's Avatar
Toxic FORMULA
Default Re: Back In The Water Again!........
I'd only change props if top end was under 4400 rpms or over 5000 rpm. You can usually improve your hole shot by going down in pitch but deep Vs aren't ones noted for getting up quick anyway.
mopower is offline
Old 08-26-2006 | 01:14 PM
Downtown42's Avatar
More hole shot may loose top end. I agree with Mopower, but you should be close to 5000 at WOT.
http://www.go-fast.com/Prop_Slip_Calculator.htm
Downtown42 is offline
Old 08-26-2006 | 01:16 PM
Downtown42's Avatar
where's the pix?
Old 08-26-2006 | 03:00 PM
t500hps's Avatar
21 and 42 footers
I'm selling a 1998 312 with the 502's (415 HP), running 30 pitch props she hits 73-74 GPS on a good day. You must be low 60's on GPS.....Should have bought mine...
Anyway, I'm suprised you are spinning 28's. As others have said, what's your max RPM?
t500hps is offline
Old 08-26-2006 | 03:24 PM
mopower's Avatar
Toxic FORMULA
Could have lower gears.
mopower is offline
Old 08-26-2006 | 03:47 PM
t500hps's Avatar
21 and 42 footers
I'm running 1.65's, wouldn't 1.5's reduce the pitch even more?
t500hps is offline
Old 08-30-2006 | 07:03 AM
K-MAN's Avatar
Here it is!
454's MPI's, 310HP, Bravo One Drives, 1.65 Ratio, 4 Blade 28 Pitch Prop
Guessing She'll Run About Low to Mid 60's?
K-MAN is offline
Old 08-30-2006 | 10:25 AM
t500hps's Avatar
21 and 42 footers
NICE!
just took a deposit on my 1998. 502/415's, 1.65 drives with 30's.
t500hps is offline
MS. 24 PANTERA
Pantera
16
09-07-2007 08:31 AM
AeroSpeedMarine
06-15-2006 10:18 AM
dhlaw
Cigarette
3
05-12-2005 08:31 AM
sgrady
07-15-2003 09:14 AM
Velocity Tom
Velocity
0
04-23-2003 08:52 PM
