382 TV removal >
382 TV removal
382 TV removal
Old 02-10-2007 | 08:32 PM
t500hps's Avatar
21 and 42 footers
Originally Posted by Magicfloat
Many of the 07 Formulas are using inverters as standard equipment. Never understood why you had to run the genset or shore power just to run a low power TV.Post what inverter you use,have a couple of customers that may want to do the swap.
A buddy bought one with 250 watts but it gets hot...probably from struggling to run the TV. I've bought a off-brand 400 watt to mount in behind the TV so that will be it's only purpose (paid $29 for it). Later, If I can figure a way to install a microwave I'm going to get another inverter to power the entire shore-power panel. That will run the microwave and the A/C!!! I've already switched the batteries to a group 27 starting and a group 31 deep cycle with massive reserve amp hours.
I'll let you know how it turns out....with out engines, I can't test the 12V system at the moment.
t500hps is offline
Old 02-11-2007 | 10:52 AM
i also have a tv inop. on my 02 38 need to remove it. a/c duct
also fell down behind. need to remove tv to fix it. were did you get instructions to remove it?
hammertime1128 is offline
Old 02-11-2007 | 05:50 PM
t500hps's Avatar
21 and 42 footers
Contact the Formula factory for help with anything you need......they WILL come through promptly. Sent me a fax or email (can't remember which) right away. Since I got the TV out I can't remember where the instructions are now.
t500hps is offline
Old 02-12-2007 | 11:26 AM
C_Spray's Avatar
Diamond Member #001
Originally Posted by t500hps
....Since I got the TV out I can't remember where the instructions are now.
I thought that I e-mailed those to you....
Hey! Just found them (direct from Formula) on my laptop. Send me your email address via PM or email, and I'll forward them out to anyone who wants them.
C_Spray is offline
randy carlson
Drives and Lower Units
4
10-24-2007 02:36 PM
littledcsrodshop
2
07-09-2007 09:08 PM
Maritime_Eng
12-26-2005 05:09 PM
