Performance Question for a 382 >
Old 02-12-2007 | 11:41 PM
to sound redundant, do boxes make a big difference. jenks
jenks is offline
Old 02-13-2007 | 02:11 AM
RedDog382's Avatar
Boxes will only produce 1-2 mph maximum on a 382. Not a big difference, but they sure look sick.
RedDog382 is offline
Old 02-13-2007 | 07:19 AM
Originally Posted by WAGS382
Your 502's will work fine for the goal's that you stated.
I have a 382 with 502's that make 620 reliable and very drivable HP that will push the boat to a honest gps speed of 83 mph.
You will need good heads but you do not need alot of compression, 9.2:1 will work well and with 89 octane.
I am running Bravo one's with "X" gears and a billet top cap I designed and built myself, no drive failures yet.
My boat does not have boxes and spins 28" bravo's 5500-5600 rpm with a 50 mph cruise at 3500 rpm.
If you want a tested a proven combo call rmbuilder and don't make the mistake of running big cams and junk heads.
Jeff
Thanks for the info! Do you have rmbuilder's # or email address I would like to talk to him.
Maritime_Eng is online now
Old 02-13-2007 | 07:20 AM
Yes they do look great. I wish I had a set on my boat!
Old 02-14-2007 | 09:20 PM
WAGS382's Avatar
This is rmbuilders email.
[email protected]
Jeff
WAGS382 is offline
Old 02-14-2007 | 10:54 PM
how much for da boxes? jenks
jenks is offline
Old 02-15-2007 | 08:36 AM
I have a pair of Stelling boxes - easy to work on good large acess windows on each side - price is 1/2 of new - good shape -
James is offline
Old 02-16-2007 | 08:42 PM
james. pm me with phone # jenks.
jenks is offline
Old 02-17-2007 | 10:25 AM
I have run both....The boat with the boxes will get on plane much quicker than the one with out. Definatly a good thing to have on the 382.
What's Mr. Nelems say on the subject??
KL
CAFormula1 is offline
Old 02-17-2007 | 12:32 PM
Charter Member #415
If I were ordering a new 382 for my own use,I would definately order Stellings.Some performance increases plus resale is better.If I were buying used I would not worry much about it,a 382 is a great boat without boxes. And if you are the kind of boater that's not big on ultimate performance and cruise around at low-mid range with gen and A/C on,the boat is a little more user friendly in those situations,and will stay on plane at a lower speed. It's all good
Magicfloat is offline
