What is this? >
What is this?
What is this?
Old 04-09-2007 | 11:50 AM
  #41
t500hps's Avatar
21 and 42 footers
Originally Posted by redcorvetteman3
I am looking for something 38' $25,000 to $35,000
I am not afraid of alittle elbow grease. And I do have a line on motors. But that just add's for money
Mike
My concern wouldn't be the work needed for this boat.....my concern would be someone coming to get. The actual history and origin of this boat is missing which means it could be stolen or hacked up from some other vessel (they could have grafted the hull # from a salvaged/destroyed hull to hide the true identity of this one.)
The chance you take isn't the $5-10K in repairs you plan, the chance you taking is every dime you spend buying AND restoring it to your liking if it does get repo'ed, etc. Just ask a number of the members here that had boats wrapped up in the National Marine mess. These guys are still making payments (or are out alot of cash) on boats they had to give back to the legal owner.
t500hps is offline
Old 04-09-2007 | 11:56 AM
  #42
How can one find out before he buys! I would think if the HIN was messed with I think it would be very noticeable. I dont know though, I do not have the boat in front of me. I agree with the whole repo and give it back to the right owner. The thought has crossed my mind.
HELP!!
redcorvetteman3 is offline
Old 04-09-2007 | 12:19 PM
  #43
t500hps's Avatar
21 and 42 footers
No one knows....you would be presented a title that says it's a 42 ft long, 15 ft wide , 14 ton vessel. We all know tht isn't the correct hull to match that ID number. It's also obvious someone has done alot of cosmetic work to dress up the boat. Would have been easy to graft a hull number in it during that process. A potential best case is the title is clean but the actual boat was destroyed, a busted up heap was used as a donor ID # and the destroyed "Stinger" was restored. They could have done a good job but if someone is trying to hide the identity it could be that the structure is garbage with a "fresh coat of paint".
Do you like Vegas....this is just too much of a gamble for me and I'd walk away.
Good Luck
Maybe look to see if you can track state registrations going back at least 5 years to give you an indication where the boat has been.
t500hps is offline
Old 04-09-2007 | 12:43 PM
  #44
I talked to Chris Craft. They said the HIN is for the right boat.
CC= Chris Craft
B=Plant location
AL= 39' Stinger
116= Hull #
J= month built
686= made is 86 but 97 model year
Old 04-09-2007 | 01:57 PM
  #45
t500hps's Avatar
21 and 42 footers
CC= Chris Craft
B=Plant location
AL= 39' Stinger
116= Hull #
J= month built
So maybe the title is wrong (15 ft beam) but everything else is OK, if that's the case proceed but make sure you get an extensive SURVEY!!!!! Could be the best $500 you ever spent.....so when do you pick it up???
t500hps is offline
Old 04-09-2007 | 03:13 PM
  #46
Joyride's Avatar
CC= Chris Craft
B=Plant location
AL= 39' Stinger
116= Hull #
J= month built
AL= 39' Stinger ??? We KNOW it's not that! So, Not Chris Craft, Not Formula. Take that "Stinger" off the side and change it to "Mystery"
Joyride is offline
Old 04-09-2007 | 04:58 PM
  #47
Originally Posted by selpel
Well if for sure does not have a 15` beam and I do not think it weights 14 ton. Someone has put a vin# on this hodgepodge and is trying to sell it as a Chris Craft Stinger. The interior of the cockpit is all C/C and down in the cabin sez C/C. To be honest this thing is spooky. Looking out of the cockpit over the nose it looks like a Wellcraft as fast as the nose drops off. What a Mess!!!
you are right it is 14 thousand sorry
ext2gtx is offline
Old 04-09-2007 | 05:08 PM
  #48
take the vin# to dmv and ask them to do a check or the troopers
ext2gtx is offline
Old 04-09-2007 | 05:28 PM
  #49
BBB725's Avatar
The bolsters look like Powerquest maybe a 257 that would explain why they needed to lift them.
BBB725 is offline
Old 04-09-2007 | 11:20 PM
  #50
bck's Avatar
bck
Charter Member#568
Based on the pictures of the Stinger that were posted, this boat seems to be a modified Stinger. It had a Formula type windshield installed which goes farther forward than the original straight one. This brought the compass inside the glass and necessitated the cutting of a notch in the center ridge. The part of the deck that used to be just in front of the windshield is now part of the dash behind the window. Look at the side panels to the rear of the bolsters, they are identical to the Stingers. The panels directly along side of the bolsters, where they used to wrap into the seat were replaced with flat panels when the bolsters were changed which is why those panels don't match the ones behind them. Also look at the raised edge along the edges of the cockpit floor and the relationship of the wheel to the controls. The reasons why this does not seem to be a Formula are too many to list. It just looks like one on the surface because of the use of Formulas two most noticable traits, the curved windshield (which isn't quite right) and the exhaust through the swim platform (which also isn't quite right for a silent thunder). So you've got a boat that seems to be a Stinger and a VIN that says it is a Stinger. But why the mistake on the beam and weight ? I think I would be more concerned with why this work was done and its quality. Your state seems to require police documentation for boats without a title and some boats with a title, so make sure all the paperwork is good.
This boat was Documented for one year from Sept. 98- Sept. 99. It was under the name Stinger and the vessel ID was D1069034 out of Ft. Wayne Ind. It also seems to have had a Ind. reg # IN2582BG. The owners name was Brian P. Greiner and the boat may have previously been called "Greiner". On the documentation the manufacturer and the year are unknown. The beam and weight are listed incorrectly as previously noted.
Straight bottoms and flat decks
bck is offline
