311 tie bar length? >
311 tie bar length?
311 tie bar length?
Old 05-16-2007 | 11:38 AM
Default 311 tie bar length?
Just scored an Imco tie bar 32.5 inches. When I measured my drives, I got 34 3/8 so I didn't want to get the 34.5". There's at least 1.5" of adj on each side so I should be good right?
Any input on how I should set up the drive alignment? I've read so much on toe in vs toe out, and some define toe differently, I'm confused. In the auto world, "toe" refers to the forward-most part, so "toe in" would mean drives pointing in / \ "Toe out" would be opposite \ /
Although, I've got probably 1/8" of play/wear in my port steering arm...
handfulz28 is offline
Old 05-16-2007 | 03:31 PM
RedDog382's Avatar
Michael,
I've tended to set mine dead even. Center of the leading edges of the drives same as the trailing edge of the drives or centerline of the prop shaft.
RedDog382 is offline
Old 05-16-2007 | 07:00 PM
CMG's Avatar
CMG
give me an hour, I have it somewhere
Chris G.
CMG is offline
Old 05-16-2007 | 07:20 PM
CMG's Avatar
CMG
or just call Chuck or anyone is c/s @ Formula and leave a voice mail - he'll call you back with the drive spacing, 260-724-1412
http://www.offshoreonly.com/forums/s...&highlight=bar
Chris G.
CMG is offline
Old 05-16-2007 | 08:28 PM
Thanks guys. I guess my 34 3/8 measurement is off because of my loose steering shaft. But I'm glad I got the 32.5 so I have room for adjustment.
Looks simple enough to install, but anything I should look out for? I need to support the drives because I'll be removing the trim cyls right? Anything I should do while I've got this stuff apart?
Old 05-17-2007 | 07:13 PM
wantsa311's Avatar
I have mine dead even, too - but I'm not looking for that last MPH so who knows how much difference it makes. When I installed it I had the drives all the way down, didn't think to support them, had no problems.
wantsa311 is offline
Old 05-17-2007 | 07:20 PM
I think dead-on is the way to go also. There was a pretty long thread over in the Tech Section a year or two back about this. More opinions than facts. Guys were talking like an eighth total out or in,,,,,,,,, hogwash!!! Line 'em up straight and run it. You'll never know the difference.
The Bird Has Spoken.
ThirdBird is offline
prostock85
Fountain
8
05-22-2007 08:34 PM
MILD THUNDER
4
06-02-2005 03:17 PM
Scarab3DMC
04-27-2002 08:30 AM
