-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   New Taco Rub Rail (https://www.offshoreonly.com/forums/formula/162707-new-taco-rub-rail.html)
Prater 07-07-2007 10:32 PM
Thanks for the link.
Treads 07-11-2007 06:40 PM
Anyone interested in going in on a 200' roll, should do 2 boats with a little left over.
masi242 07-11-2007 08:40 PM
nice job, it cleans it real nice.
mtgbiker 07-11-2007 09:23 PM
Thanks,
I figured White rub rail would update the look of my older bird!
also,
I believe Formula changed from Black to White in 95 or 96?
handfulz28 07-12-2007 01:39 PM
How was your rail attached to the ST platform? Mine's done with rivets instead of screws like the rest of the boat.
Treads 07-12-2007 04:05 PM
Mine is the same also.
mtgbiker 07-12-2007 05:03 PM
Ditto, Ditto
Drill em' out...seal em' with 5200 and drill new holes since Taco's rub rail comes pre-drilled (8" on center) anyway!
freddan 01-03-2008 07:28 AM
Originally Posted by mtgbiker (Post 2189003)
iboats.com
Frosty White-Perfect match
The Artic White is too white.
http://www.iboats.com/1_7_8_Frosty_W...view_id.271971
I hope this link works. If not, I can send you a PM. Let me know.
Oh no... cant find the Frosty white rubrail on their site? I was just about to place an order:(
Is it available somewhere? Please help!
propwash 01-04-2008 07:36 PM
Hey guys, I just got done doing this rub rail replacement and I would recommend to get some samples of the different profiles and colors you think you may want for your boat. Take a piece of your rub rail off and then put the sample up to the boat and see if it's going to cover where the old one was. This is not the easies job to do and very time consuming but worth ever minute when it's done. I did use the Taco's rub rail that I believe measured 1& 15/16 in height. Take your time and I'am sure it will turn out real nice. Sorry I don't have any pictures but I wish I had. Changing the rub rail is a big improvement to these old birds. Propwash.
MOERON 01-04-2008 08:09 PM
Did the old rub rail unscrew from the screws on the outside? I was once told you had to remove the interior upholstery!
