Cockpit drains 357 >
Cockpit drains 357
Cockpit drains 357
Old 11-05-2007 | 11:23 AM
offthefront's Avatar
Some of the older boats had a pump up in the cabin drain area ...does the water flow to a well area forward where a pump could be or once was mounted ? On the 311 there is a thru hull fitting thru the rear of the back seat ... On Jeff32's pic of the drain ...go up about 2" and then a hose attaches (about 18" long) to the thru hull and and just drains into the bilge .... I would plug the other drain and drain it like the 311 ..... I'll get a pic ...
offthefront is offline
Old 11-05-2007 | 11:28 AM
Look below Starboard trim pump ...this pic shows the hole without the thru hull ... and then a short hose that turns down after the deckplate .....m
Old 11-12-2007 | 07:32 PM
jeff32's Avatar
offthefront! You really did a nice looking bilge job!
jeff32 is online now
MadMat
05-29-2013 07:12 PM
vendetta
Awesome
21
08-17-2007 03:21 PM
Poorsche
03-15-2005 04:36 PM
Pat McPherson
Superboat
6
04-30-2003 09:41 PM
US1 Fountain
Fountain
1
04-15-2003 12:02 AM
