First Run ....Not So Good >
Old 09-19-2007 | 12:13 PM
Originally Posted by Perfectmix
So was there waterin the oil? How about the oil filter? Did you cut it apart and was there metalic substance? Hopefully not catastrophic and just a good refresh will get you back in business. On the brighter side at least you found this before spring and are able to have things fixed for next season. You will also know exactly what you have when this is done. Good Luck man!
I pulled the dipstick andit seems the oil is fine. To me i have yet to find the real problem. I was thinking last night that when the motor comes out. if i do not find the "smoking gun" then it must be in the trans. I grabbed the prop last night and spun it in neutal and there was no grinding or clunk in the drive.
Car Biz is offline
Old 09-19-2007 | 12:37 PM
Originally Posted by axapowell
Loss of rpm's and grinding noises are never good. If it was knocking too...well, I'd start at the bottom end and work my way up. RPM loss is usually something starting to seize up, like a main or a rod bearing. Good Luck with it. Lots of help here for you!
Dave
I just want everyone to know that i did email the previous owner and i did ask him for anything i just thought he should know. He has offered me some parts if i pay the shipping. i say that is a stand up guy
Car Biz is offline
Old 09-19-2007 | 01:15 PM
Head bolts rusted? Spark plug rusted? How do the exhaust manifolds look? Sounds like a leaky manifold/gasket?
Since you're game for having them pulled at least they'll be easy to work on. If you're willing/able, please share what you find, including pics.
handfulz28 is offline
Old 09-19-2007 | 07:53 PM
jaybird's Avatar
Sorry to hear that, ouch!
I know of some nice 525's you could put in - they come with a 311 spare boat ha!
Good luck!
jaybird is offline
Old 09-20-2007 | 09:11 PM
offthefront's Avatar
did you run the motor in Neutral ?
offthefront is offline
Old 09-21-2007 | 07:29 AM
Would not fire. tried to fire it at the dock and i would not turn over fast enough to hit up.
Car Biz is offline
Old 10-08-2007 | 02:16 PM
Well i took the filter off cut it apart and nothing it was clean. No metal or pieces of silicone nothing! Good news is i picked a couple 370 MAG motors that i am having worked on. One is complete and one needs a pair of rectangle port heads one head is cracked
Although i knew that when i bought them. I will keep everyone posted as i get more info.
Car Biz is offline
Old 10-27-2007 | 10:07 AM
Well here is a couple pics of the motors i took out. the second pic shows the rusted spark plug in the cylinder that i think went bad. looks like it has been that way awhile. I just cannot believe the rust on these.
To top it all off I bought some 370's from a guy that told me that one motor needs work the other runs perfect. WELL took them to my builder each motor had burnt pistons. Felice figured well since the cylinders were scored so bad lets bore them. Well the blocks, rods are GREAT now i have a pair of 462's. Went to check the heads. And more bad news the set of rectangles that were suppose to be good are cracked This is going to be a LONG LONG winter. Man am i just pissed right now.
Attached Thumbnails First Run ....Not So Good-330s-007.jpg   First Run ....Not So Good-330s-004.jpg
Car Biz is offline
Old 10-27-2007 | 10:19 AM
HiPerf2000's Avatar
and you say you had this boat surveyed ??
HiPerf2000 is offline
Old 10-27-2007 | 10:28 AM
CB I am sorry to hear this, what a pain
88242LS is offline
