Silent Thunder help >
Silent Thunder help
Silent Thunder help
Old 11-11-2007 | 06:17 AM
masi242's Avatar
Good luck Mo, keep us up to date on the project.
masi242 is offline
Old 11-11-2007 | 07:56 AM
mopower's Avatar
Toxic FORMULA
Will do.
mopower is offline
Old 11-11-2007 | 08:07 AM
offthefront's Avatar
I see what you talking about now .... My box is not back on yet ....The mount on the Transom for the Rams is just below the Gasket for the ST and I'm thinking we took some measurements and it was close but would be ok ...cept that just clearance for the mounts ...your saying as the rams come up to trim the will hit the box below the exhaust outlets ?
offthefront is offline
Old 11-11-2007 | 06:43 PM
mopower's Avatar
Toxic FORMULA
Well , I'm going to lose from the crease(and pipes) down
Mine would be SO close I wouldn't be able to tilt the drives above the lowest part of the boat and that is in the straight position. Have the wheel turned and it only gets worse. So if I got into a shallow situation I could be screwed.
mopower is offline
formula2?2
07-30-2017 09:54 AM
ninetym
07-02-2008 09:58 AM
sneekinfreek
10-12-2007 10:47 AM
Gearhead2
05-13-2005 07:04 AM
RUSSSR1
06-24-2002 12:38 PM
