292 Fastech Battery >
292 Fastech Battery
292 Fastech Battery
Old 04-17-2008 | 10:26 AM
Default 292 Fastech Battery
Can anyone confirm that the port side battery on an 02 292 Fastech is the battery that runs all the accessories, and the startboard is just the cranking battery for the starboard engine.
Splitdecision271 is offline
Old 04-17-2008 | 02:57 PM
rhsj2006's Avatar
Confirmed - A service shop recently left some breakers on and killed my port side battery.
I had to bridge both batteries before anything would work.
rhsj2006 is offline
Old 04-17-2008 | 11:01 PM
Expensive Date's Avatar
Hey Split I have an Interstate port side one year old loaded out fine on a regular load tester but failed using my Mid Tronics.Should still be under warrenty.But I put a Deka back in.If you want it its yours
Expensive Date is offline
Old 04-18-2008 | 08:09 AM
Thanks Tim, but I picked up to brand new interstate batteries. My buddy works at a dealership that gets interstate batteries. Got a group 27 deep cycle & a group 24 XHD cranking battery at dealer cost. So I got both for what you would pay for the one deep/cycle, pretty good deal. They got a two year warranty on them too. Put them in last night, and started her up for the first time, turned right over. Only issue I'm having is with the port side trim tab, it ain't working, starboard works fine, gonna work on it on Saturday. Gonna switch the lines to see if that works also gonna check the wiring at the switch. It's making contact at the pump but ain't budging. I can hear it bubbling when I hit the up button, but down does nothing.
rhsj2006
04-10-2008 10:35 PM
vscorsa
12-15-2007 08:21 AM
jmeng
02-10-2007 07:33 PM
4mulafastech
12-01-2005 07:54 PM
HelmPilot
10-05-2004 02:07 PM
