Engine alarm at initial startup only...454/330 >
Old 05-28-2008 | 10:12 AM
Default Engine alarm at initial startup only...454/330
Anyone ever had an engine alarm come on immediately at [cold] start-up, for no apparent reason? Oil pressure and everything else seems to be OK.
If I let engine warm up for a few minutes, then shut it off and immediately re-start...there's no alarm. Same thing if I stop at a dockside restaurant, eat and re-start...no alarm. Boat is '87 F242LS 454/330 with Alpha.
Could a voltage/alternator problem be causing this? It is possible my batteries may not be charging properly, as I did have a problem with this two weeks ago.
BlackJack58 is offline
Old 05-28-2008 | 12:25 PM
RedDog382's Avatar
Drive lube reservior level ...?
RedDog382 is offline
Old 05-28-2008 | 06:04 PM
masi242's Avatar
Reddog, we don`t have reserviors on the alpha.
Black, I have had mine for six years,and last year I changed the thermostate and new impelliour(sp). Now this year after a short run the temp will climb from 160 to over 210 when I come down to an idle. If I shift it into forward with a little gas it will come down. I am headed to the boat thurs. afternoon to put in a new temp sensor.
masi242 is offline
Old 05-28-2008 | 06:23 PM
If my battery is low enough it will scream on the port motor. Once I get the starboard side fired up if I shut the port down and re-fire it, it never comes on.
Just something to think about.
PJDiesel is offline
thanks_don
11-19-2006 08:24 PM
Jamie Bowman
22
10-23-2006 08:14 PM
slgr24
11
05-10-2002 07:28 PM
Bo Knows
03-18-2002 12:25 PM
