fastech anchor >
fastech anchor
fastech anchor
Old 07-10-2008 | 09:31 PM
Default fastech anchor
What is the best place to store the anchor on a 312 fastech and what size or kind works best. Thanks
ur2slow is offline
Old 07-11-2008 | 01:49 AM
PhantomChaos's Avatar
In the cockpit side storage area........
PhantomChaos is offline
Old 07-11-2008 | 06:24 AM
FRMULTR's Avatar
Burnin' Love
I will second that statement.
FRMULTR is offline
Registered User
I will third that...
Shameless is offline
Old 07-11-2008 | 07:31 AM
Default anchor size
GOES BY SIZE AND WEIGHT OF your boat , ROAD / ROPE normely is about 4' to 1' of depth of water also know what type of bottom you'll be boating in anchors do make a differant's , always use a galvenize or plastic coated chain at least 3' from rope to anchor that helps it set on the bottom
tony manzella is offline
Old 07-11-2008 | 08:07 AM
I got a west marine 8LB traditional fluke anchor. I store it up front in the anchor locker. Fits nice and tight, doesn't move really have any room to move when it's in there, hasn't caused any sort of damage yet. Anchor rope is 100' by 1/2" and 6' or vinyl coated chain. I would definately recommend the vinyl coated chain, won't scratch the top deck, if you accidently drop it or if it rubs against it.
Splitdecision271 is offline
Old 07-11-2008 | 02:00 PM
No damage? You must not boat in the ocean or on a lake with swells ?
Old 07-11-2008 | 09:15 PM
I had it out in the Bay for the first time two weekends ago. A little bouncy on the way home at the end of the day, checked out the locker, the anchor hadn't moved. Mainly boat on inland rivers, generally flat, maybe a foot of chop on a "bad" day. Haven't been able to get out the past few weeks, had a water pump go, and now am dealing with some type of power issue. Starboard engine won't turn off.
Old 07-13-2008 | 12:55 AM
sleek1's Avatar
Box anchor 2:1 rode.
sleek1 is offline
firstoffshore
03-03-2021 07:56 AM
pwrbotr
03-02-2021 04:16 PM
Maritime_Eng
10-22-2006 01:26 AM
kjm5125
04-19-2006 08:45 PM
Dave M
03-27-2003 11:53 AM
