Gas Smell
Old 11-10-2009 | 08:14 PM
88formula223's Avatar
NO WAKE ENFORCER
feel under the step in the cuddy that's where the gas was pooling when my tank went bad
I contacted formula and they sent me the original plans for the fuel tank and they made it to Formulas specs
I got mine here 3-4 years ago for around $650, good quality and I paint my mechanic to put it in he said it was a ***** to get out
http://www.speedytanks.com/home.html
88formula223 is offline
Old 11-24-2009 | 09:43 AM
Do u still have specs? If so can you email them to me
[email protected]
BiLLyLaurianO is offline
Old 03-01-2010 | 02:32 PM
can you pm me your name, I called them and they might still hav e your specs on file so i can order a new tank.. thanks
Old 03-09-2010 | 03:38 PM
If you're about to replace the tank you may want to check out this page where I documented the work I had to do after discovering that there was a big hole in my gas tank. See this page and especially the part on the leaking tank:
http://raffinaderiet.com/Formula/index.html
Klas233 is offline
Old 03-10-2010 | 12:28 PM
axapowell's Avatar
Where To
I just checked out that link...WOW Nice Job! Much better then new. You should link that to the upgrade post! I'm sure Formula People will want to see it!
Dave
axapowell is offline
Old 03-10-2010 | 12:48 PM
Dave
Thanks Dave / axapowell, I appreciate it. Yeah, maybe I'll post the link there too. That way I will hopefully feel that I should update the pages as well :-)
Klas233 is offline
Old 03-15-2010 | 02:33 PM
so what if i drop it in with no foam and strap it down.
Old 03-15-2010 | 06:23 PM
offthefront's Avatar
Unless I missed Something .....What did you find on the old Tank? While the Job Klas233 did was Outstanding I'm not sure I like the idea of the tank being Supported by just the wood frame? The SS was a good Idea ...With Some of the Pounding my 311 takes I would want all the support I can get. Also the Original settup did last 28 years ......m
offthefront is offline
Old 03-16-2010 | 10:31 AM
boilerdaddy's Avatar
Offshoreonly Advertiser
Commercial Members
Billy, I found the original drawing for the tank. I will email it to you. You may also want to reinforce the hull bottom with pultrusion. If you like, give me a call at 260-724-1412. Scott
Hoosier by birth, Boilermaker by the grace of God!
boilerdaddy is offline
Old 03-18-2010 | 07:57 AM
I got these from Scott at forumla.. Very helpful Guy. Tank is being custom made. Will update soon
