re-setting the windsheild >
Old 05-26-2010 | 11:17 AM
Originally Posted by offthefront
Are the screws under the Rubber Gasket? So you pull the Gasket , remove the screws and then you could remove the entire Assembly? Is it leaking between the frame and the weather stripping?
What I would like to have is a new rubber Gasket ..... I cant believe its not available or at least there isn't someone that could make some up ....Maybe if we bought 10 sets ? ........m
are you talking about the filler strip? or the actual gasket between the frame and hull??
theadamv1 is offline
Old 05-26-2010 | 12:36 PM
offthefront's Avatar
Filler Strip ...
offthefront is offline
Old 05-27-2010 | 07:26 AM
Filler Strip ...
My 88 actually has molded plastic filler strip that snaps in the channel where the screws secure the w/sheild frame to the hull to conceal the screws..
Old 05-27-2010 | 10:21 AM
Audiofn's Avatar
Charter Member #232
I think that there are some bolt that you access through the side panels and then in the front of the windsheild you have screws under the rubber. Mine is like "theadamv1" with just a almost flat plastic filler. I would like to get new one however as mine has also shrank a bit.
Put your best foot forward!
Audiofn is offline
Old 05-27-2010 | 07:01 PM
Where the Curved windshields meets on my 89242LS has this shrinkage.... Can we fix it or have to replace it??
pdm007 is offline
Old 05-27-2010 | 08:24 PM
Count me in .... I need to the same thing .....
I had 5 guys lift it off and "seal it" .... worked until I used my boat with the bimini top up.
Ever since then it has leaked again .... what a pain in the azz!
Jeff
got twins ? is offline
Old 05-28-2010 | 09:27 AM
I would be in for a gasket as well. I have one side that has the flat plastic part and the other has nothing.
jmrapp is offline
Old 05-28-2010 | 06:26 PM
I'll do some checking next week .....m
