Trailer for 292 >
Trailer for 292
Trailer for 292
Old 08-04-2010 | 07:11 PM
sent.
1MOSES1 is offline
offthefront's Avatar
Originally Posted by moses0324
^^^ im buying it tomorrow. looks like its in good shape. thanks.
Make sure ....the rating is ok for your 292 ... I would say 10K?
offthefront is offline
Old 08-04-2010 | 07:19 PM
yea wet weight is about 8000 lbs...
how much do these aluminum trailers weigh? 1000 lbs?
if so it gives me 1000 lb wiggle room. all the trailer manufacturers "float-on", "fastload", "rocket", and "all american" were fitting me with the same size trailer....
1MOSES1 is offline
Old 08-04-2010 | 07:26 PM
I would say 1200 tops ....
Old 08-04-2010 | 07:33 PM
i think that allows me enough room for weight...the boat wont be topped off while on the trailer anyways.
1MOSES1 is offline
Old 08-04-2010 | 08:04 PM
Just fyi - this is what the bunks look like on my Prestige trailer for the 292. Supports it nice in all the right places. After receiving their first 292 they took measurements on the hull and designed a trailer.
4mulafastech is offline
Old 08-04-2010 | 08:38 PM
Expensive Date's Avatar
Really nice trailer.You do know that Prestige was closed/sold here is a link I found looking for there website.
http://www.regalownersforum.com/foru...hp?f=32&t=1364
Expensive Date is offline
Old 08-05-2010 | 08:19 AM
Thanks. Wow, I didn't know that the original owners sold the business. They are very popular around here in the midwest. Looks like Heritage Trailers will continue the Prestige design.
Old 08-06-2010 | 06:52 PM
i just bought this trailer...
http://www.offshoreonly.com/classifi...o35371-en.html
i need to modify it to fit a 292 stepped hull...what is the easiest method. i think the middle bunks need to be dropped but what about the outside bunks?
thanks.
1MOSES1 is offline
Old 08-06-2010 | 08:13 PM
thanks.
ok .... the way I see it ....and depends on the step size ..
On the 353 the first step is 1.5" and second Step is 1.25 ....So ...you will need one 2x6 placed on top of the existing bunks to run from the Transom all the way to the second step ....then starting at the begining of the second step you will need another 2x6 on top of the first 2x6 to run from there forward to the first step ... First you will need to check the angle cut on the existing Bunks ....292 is 23* on both steps and the the bow is 25* ...I think ...check the diagrams you have ....Best way would be to have new bunks cut out of Cypress but costly ....and I am not sure if my way is not just fine ......I would glue and lag bolt the 2x's to the bunks ..countersunk ....m
