Put the bird in a nest >
Old 02-22-2012 | 11:02 AM
  #91
PhantomChaos's Avatar
I figured unprotected (non-plated) aluminum structure and stainless screws combined with moisture (fresh or salt) caused most of this corrosion. I'm adding these Polyelastomer Cushioning and Sealing Washers .060" thick against the powder coated parts. Generally it will be:
Screwhead > SS Flat Washer > Poly Washer > Part > Poly Washer > Part > Poly Washer > SS Flat Washer > SS Locking Nut
PhantomChaos is offline
Old 02-22-2012 | 11:46 AM
  #92
Audiofn's Avatar
Charter Member #232
Sounds about the same as what Porsche does. Maybe a mylar film could work as well?
I found one of those tables. This one is for salt water.
http://www.eaa1000.av.org/technicl/c...n/galvanic.htm
Put your best foot forward!
Audiofn is offline
Old 02-22-2012 | 12:38 PM
  #93
C_Spray's Avatar
Diamond Member #001
I just counted on the powder coating and a dab of Tef-Gel corrosion inhibitor. So far, so good, but I'm in 98% fresh water, unlike you. Good thinking.
C_Spray is offline
Old 03-02-2012 | 04:29 PM
  #94
Assembly Time! Trying to get it done and delivered tomorrow. Engines go in next week.
Attached Thumbnails Put the bird in a nest-1.jpg   Put the bird in a nest-4.jpg   Put the bird in a nest-5.jpg
Old 03-02-2012 | 04:44 PM
  #95
Audiofn's Avatar
Charter Member #232
Lookin good Nort. I can not beleive you are working so close to your car!
Audiofn is offline
Old 03-02-2012 | 09:59 PM
  #96
C_Spray's Avatar
Diamond Member #001
Man! That looks familiar. I remember seeing that every time that I closed my eyes four years ago!!!
C_Spray is offline
Old 03-03-2012 | 11:02 AM
  #97
Getting it done. I have to go modify the "T" part right now before I install that. Need to relief the hinge area more.
Attached Thumbnails Put the bird in a nest-10.jpg   Put the bird in a nest-11.jpg   Put the bird in a nest-12.jpg
Old 03-03-2012 | 11:18 AM
  #98
+1 Is that a CL63?
JTeam is offline
Old 03-03-2012 | 06:41 PM
  #99
Originally Posted by JTeam
+1 Is that a CL63?
Yes.
All fixed. Watching glue dry now.
Attached Thumbnails Put the bird in a nest-20.jpg   Put the bird in a nest-21.jpg   Put the bird in a nest-22.jpg
Old 03-06-2012 | 10:56 AM
  #100
All done......delivering today! A nice improvement!
Attached Thumbnails Put the bird in a nest-1.jpg   Put the bird in a nest-30.jpg   Put the bird in a nest-31.jpg
