Put the bird in a nest >
Old 12-07-2011 | 11:34 AM
  #61
PhantomChaos's Avatar
Another "while we're doing all this"....................
PhantomChaos is offline
Old 12-07-2011 | 04:23 PM
  #62
C_Spray's Avatar
Diamond Member #001
Just went through that whole thread again. I've got a ways to go yet.
Since I'm retired now, why don't you just pay me to fly out there and finish this little beauty?
Oh - WAIT!!!!
What is your budget?....
C_Spray is offline
Old 12-07-2011 | 05:47 PM
  #63
tomtbone1993's Avatar
nothing like using a S Class to move your parts....
tomtbone1993 is offline
Old 12-08-2011 | 07:12 PM
  #64
Is there something else?
Attached Thumbnails Put the bird in a nest-1.jpg   Put the bird in a nest-2.jpg   Put the bird in a nest-3.jpg
Old 12-08-2011 | 07:14 PM
  #65
More.....
Attached Thumbnails Put the bird in a nest-6.jpg   Put the bird in a nest-7.jpg   Put the bird in a nest-8.jpg
Old 12-08-2011 | 07:15 PM
  #66
Last for today....
Attached Thumbnails Put the bird in a nest-12.jpg   Put the bird in a nest-13.jpg   Put the bird in a nest-14.jpg
Old 12-08-2011 | 10:17 PM
  #67
Question...........why did Formula install the bilge pumps and associated float switch on a small unfinished aluminum plate on each side? Look at this $hit.
Is it an attempt to keep the pump and switch level? If so.....why not mount it on stainless or finish the metal? Why would it need to be level?
I'm replacing with new pumps and a "digital" float switch (no moving parts).
Attached Thumbnails Put the bird in a nest-p1.jpg   Put the bird in a nest-p2.jpg
Old 12-09-2011 | 07:02 AM
  #68
Audiofn's Avatar
Charter Member #232
Nort your third picture three posts up.... I think they should have the kneel down pad in the office no?
The floats work better when level. If they are at an angle they will suck air about the same time as if at an angle anyway. So unless you have a flat spot in the bottom of the keel then what they did is about all you can do, or mount them to the stringer. As for the Allum. vs. Stainless I guess it really does not matter. Stainless would look the same as what the allum does less the galvanic corrosion.
My concern would be on the size of the pumps. Those look real small to me for that size boat?
Put your best foot forward!
Audiofn is offline
Old 12-10-2011 | 12:37 PM
  #69
C_Spray's Avatar
Diamond Member #001
Nort, I had a lot of corrosion on all the various raw aluminum bits in my boat as well. Take them all (including the supports for the platform in front of the engines and get them media0blasted, then powdercoated white. That'll fix 'em. Good idea on the solid state switches. Use Deutsche or Weatherpack connectors when you put them back in in case one craps out on you in the future.
C_Spray is offline
Old 01-10-2012 | 01:07 PM
  #70
Step in progress
Attached Thumbnails Put the bird in a nest-img_3738.jpg   Put the bird in a nest-img_3740.jpg   Put the bird in a nest-img_3742.jpg
