silent thunder gasket/seal >
Old 03-30-2011 | 08:37 AM
Default silent thunder gasket/seal
I looking to see if anyone can tell me the best gasket/seal material to use to re-attach my silent thunder. I don't want to use any sort of caulk/adhesive that would make it hard to remove in the future should I decide to take it off again. must be something out there that you guys are having good success with.
thanks
Dennis
ddabal is offline
Old 03-30-2011 | 08:26 PM
masi242's Avatar
I took mine off a few years ago and replaced it. I bought one from Nelmes marine, Robert is on the site. I hate to say it but it looks like heavy duty weather stripping. Or just try a Formula dealer $$ it`s not that bad.
masi242 is offline
Old 03-30-2011 | 08:50 PM
OldSchool's Avatar
From 8 years ago when I was the artist formally known as Craig223.....but that's the beauty of this place..
Formula is a great company. You can most likely still get the gasket from them.
http://www.offshoreonly.com/forums/f...placement.html
OldSchool is offline
Old 03-31-2011 | 09:06 AM
offthefront's Avatar
if you have a local Rubber materials supplier you just need a "D" shaped Gasket ....glue the flat part of the D to the Transom ....also a ring around each exhaust outlet ......m
offthefront is offline
