382 Grab Rail >
382 Grab Rail
382 Grab Rail
Old 10-19-2011 | 08:31 PM
Default 382 Grab Rail
Port side grad came loose on the port side. It appears one anchor point can be accessed in the V-berth and the other in the main cabin.
How much trouble is it to get to?
kjm5125 is offline
Old 10-19-2011 | 08:48 PM
Default Grab Rail bolts
You should be able to get to them except the one behind the fridge. I pitched my fridge so its accessable. The cabin speaker covers and speakers have to come down. Phillipps screwdriver (shortie). Through the speaker holes you can reach them, Do not overtighten, It will crack the gelcoat. The rears from the engine compartment, midship, pull the 6x9 speaker and reach up. I think they are 9/16 bolts. Good luck.
fossil fuel is offline
Old 10-19-2011 | 09:28 PM
t500hps's Avatar
21 and 42 footers
As Fossil Fuel stated.....I had my frig out 2-3 times over the years for running wires etc. so you can get in there if needed.
t500hps is offline
Old 10-20-2011 | 09:20 PM
Thanks, the two I need to tighten are before the fridge. The one in the in the V-berth might be more effort.
kjm5125 is offline
