Efficient hull >
Efficient hull
Efficient hull
Old 08-08-2002 | 09:18 AM
Audiofn's Avatar
Charter Member #232
I have been on Both of Norts boats and you are correct. NO EXPENSE SPARED!!! If they need something they get it and they are both FLAWLESS!!!!!! Some one is going to get a good deal on that boat.
Jon
Put your best foot forward!
Audiofn is offline
Old 08-09-2002 | 09:37 AM
BigDaddy96's Avatar
Question Stepped vs Non Stepped Hulls
Ok don't make too much fun of me here guys, I'm relatively new to boating. Can anyone explain the diff between these two hulls or post some pics of them?
BigDaddy96 is offline
Old 08-09-2002 | 02:04 PM
groove's Avatar
I'm new as well but think I can help here. Once up on plane you ideally want just your props in the water. Any part of the boat that is touching adds friction and slows you down. Since we all know you can't keep all of your boat out of the water, they cut steps on the bottom of the hull in the areas that are most likely going to be in contact with the water while on plane. Since the hull suddenly disappears and then restarts, it causes slight turbulance, which makes air bubble. The air bubbles have much less frictions than solid water so you can go faster.
Only drawback is it can cause some strange behavior when handling. Instead of cuting through the water, you are slidding across.
Did I make any sense?
groove is offline
Old 08-12-2002 | 01:55 PM
blown formula's Avatar
ALSO, and this can be important.... I did not think about it before I bought my 312, but A stepped hull boat will NOT allow you to read bottom depth with the internal transducer because of the step, so you cannot see if the bottom is coming up at you! This is important if yoy are running in moderate depths of water as in up channels or rivers & inlets.
You must have an external transduer to read the bottom at speed. If someone has another fix for this I would like to hear it!!
blown formula is offline
Old 08-12-2002 | 01:59 PM
PhantomChaos's Avatar
They originally had the tranducer in the engine compartment area. Now I believe they install it up inside the hinged step as you walk into the cabin.
PhantomChaos is offline
Wobble
07-11-2006 11:41 AM
BadDog
7
05-17-2006 06:50 AM
BryanTuvell
Cigarette
4
03-04-2003 11:17 AM
