DVD TV replacement >
DVD TV replacement
DVD TV replacement
Old 01-18-2015 | 10:54 AM
badmonkey's Avatar
Default DVD TV replacement
Need to replace the TV/DVD in the Fastech. Where have you guys gone to get a new TV/DVD unit for yours?
Thanks,
Chris
badmonkey is offline
Old 01-19-2015 | 12:59 PM
I did this a month or 2 ago... Ended up doing this with a mount from WalMart...
http://www.bestbuy.com/site/insignia...&skuId=2127006
I thought mine was a 32 but It could be a 28", I'm not sure... I have a 330 and this fit nicely
alindquist is offline
Old 01-20-2015 | 07:38 PM
aquaforce's Avatar
I went to Sams club and got a Vizio to stick in the 357. There was a nice heavy duty aluminum TV mounting bracket that would swivel on ebay. It looked to me like it could take a pounding with out any problems so that is the route we went.
aquaforce is offline
Old 01-20-2015 | 09:49 PM
VoodooRob's Avatar
Post up how this goes, I'm interested in the r&r in the 353. From what it looks like the mirror has to come out of the head to get to the brackets. Hopefully I'm wrong, I need to do this job shortly too.
VoodooRob is offline
Old 01-21-2015 | 06:09 AM
badmonkey's Avatar
You are correct. The mirror does have to come off in order to access the brackets. I will be getting to this task next month. I will post some pics if you need them. I really do not think this process is a big deal though. Finding the right TV will probably be harder....
Chris
Old 01-21-2015 | 07:50 AM
If your boats are anything like mine good luck getting the mirror out. It's screwed in and glued down with mastic, I wasn't able to get it to budge even with suction cups. What I ended up doing was taking a skill saw to the original mount to open it up and get access to the bolts. Once it was open I was able to get the bolts and the rest of the mount off. After that it was easy, just drill a few holes in the mirror with a diamond core bit and mount the bracket. I did run a few zip screws into the mount and the bracket to keep the TV from bouncing off the mount.
Old 01-21-2015 | 12:59 PM
Who needs a TV. It ain't called a stabbin cabin for no reason. Just sayin.
sonicss42 is offline
Old 01-21-2015 | 03:49 PM
axapowell's Avatar
Where To
No need for any prying it off....
I already did the hard work there. The TV works fine, the DVD is intermittent.
Under the TV are two Philips screws, remove them and slide the TV up and off. No need to mess with the mount on the mirror, it's solid.
The new TV will have the same mounting holes as the bracket on the existing TV and slide right back into place.
DONE!
Don't make me fly out there just to put a new TV in......
Dave
axapowell is offline
Old 01-21-2015 | 06:54 PM
badmonkey's Avatar
DONE!
Dave
I think you flying out here to put the new TV in is a great idea...excuse too drink and laugh....
Can't have intermittent DVD during adult movie night....
Thanks Dave.
Chris
Old 01-21-2015 | 07:35 PM
VoodooRob's Avatar
DONE!
Dave
AXA, did you modify the tv mount or is that how you remove the stock tv? Thought the mirror in the head had to come off to access? Thank you for posting.....how about finding a pair of the cnc steps laying around? You would not believe what the factory wants for the sets in stock!
