fastech cabin bench storage >
Old 05-09-2016 | 11:20 AM
Default fastech cabin bench storage
I'm fairly sure all the fastech cabin bench seats are the same and from the factory, not hinged. I know at least my old 271 and my current 312 are that way. Has anyone ever added hinges to gain storage space beneath them? It blows me away formula didn't do that from the factory. Anyway, if anyone has done this, what did you use? I suppose I would need a hinge similar to the rear bench seat.
racinfast002 is offline
Old 05-09-2016 | 11:44 AM
Do you know if there is a compartment under there? On my 272 and 311 the couches are screwed down to a carpeted flat surface, no compartment there.
Mr Maine is offline
Old 05-09-2016 | 12:39 PM
t500hps's Avatar
21 and 42 footers
I had a 98 312 and removed the head to install an A/C unit. I removed one of the benches to run plumbing and was surprised how little space is actually under there. Even 6 inch fenders do not fit! Don't waste your time cause you'll only be able to put a couple dock lines and a towel under each side.
t500hps is offline
Old 05-09-2016 | 12:47 PM
I know there isn't much space under there. I had them out on my previous 271 fastech. However, SOME space is better than the no space I have now. I love a lot of things about the Fastech line, but they don't have much for storage. I just want to gain a few more hidey holes for stuff.
Old 05-11-2016 | 08:24 PM
Took my fridge out after wifey fergot a shrimp salad in there for a month. Threw it in the trash. Wow what a great space to store stuff. Soft sided cooler works great.
fossil fuel is offline
Old 05-11-2016 | 11:35 PM
It's your job to see that the boat is clean!
Level III Chaos is offline
Old 05-11-2016 | 11:41 PM
I imagine that since it's supposed to be an ocean going luxury performance boat that they anticipate it to maybe hit some rough water once in awhile so hinged seats and a locking fastener would be asking for trouble. The closer you get to the stern the smoother the ride is.....so I can imagine in the rough those seats would come undone pretty quick and you would be collecting even more cupholders full of miscellaneous hardware off the cabin floor.
What do you want to put there? DOPE????
Old 05-12-2016 | 08:31 AM
I think that there is a slight radius to the fixed bottom cushion? Tough to get a hinge to behave in that installation. Piano hinge not a chance.
