Removing fuel sender 311... >
Old 06-06-2016 | 02:38 PM
Default Removing fuel sender 311...
So what's the trick to getting it out? Seats in the way?
stlliberator is offline
Old 06-06-2016 | 05:36 PM
I answered this on your other thread. It's the only way to do it unless you want to separate the deck from the hull.
Mr Maine is offline
Old 06-06-2016 | 06:32 PM
So just remove the bottom part of the back of the back seat and just drill a hole?
Old 06-06-2016 | 06:36 PM
Yeah if you use the correct size hole saw its pretty clean and you'll never see it. If you can get your new sender in without drilling the hole you could just bent the old one to get it out which would ruin it
Mr Maine is offline
Old 06-07-2016 | 08:17 AM
offthefront's Avatar
As stated you can remove the old float style sender from the engine room but it destroys it ..... then go with the new style single tube and I think we got in from the engine room ......m
offthefront is offline
Old 06-07-2016 | 11:57 AM
Mine has a screw in access hatch below the rest seat
switchbackman is offline
Old 06-07-2016 | 09:03 PM
Mine doesn't I don't think. I haven't removed my back seat yet.
Old 06-12-2016 | 03:52 PM
Anyone have pictures of what they did??
