New guy with 242 questions >
Old 12-01-2016 | 11:11 AM
  #131
I believe I'll be in this blue one for 10 or less if it goes correctly. And it's much closer to home lol. If it falls through I'll check that one out. I bet it will get into the 60s with a 496 in it?
Redneckcustoms13 is offline
Old 12-01-2016 | 01:01 PM
  #132
I have a hull with the hooks removed. My boat with a 420hp went 62. I now make 550hp after heat has soaked in, I get 72-73.
79formula is offline
Old 12-01-2016 | 02:19 PM
  #133
I want reliable over fast. I have a vector to go fast in. I want to cruise about 35-40. If a wot run is 55 I'd be happy. He claims it will do 65 but I imagine he is basing that off the speedometer ln the dash not gps numbers.
Old 12-01-2016 | 03:24 PM
  #134
for reference my '89 with bone stock 850 hour non-mag 7.4, 1/4'ish tank of fuel, and one other person does about 53 on gps at 4700 with a 21p mirage plus.
bbender785 is offline
Old 12-01-2016 | 03:27 PM
  #135
Block Code is mc43014. Decoder says mc was a 69 model 427?
Old 12-01-2016 | 03:33 PM
  #136
TomZ's Avatar
Where are you getting that code from?
TomZ is offline
Old 12-01-2016 | 03:37 PM
  #137
Front of block to left of timing cover.
Old 12-01-2016 | 03:50 PM
  #138
TomZ's Avatar
That's not right.
If it is a MK-IV, the pad is directly above the timing cover on a flat, machined pad along the top of the gasket sealing surface for the timing cover. If it's a Gen V or VI, it's on a pad just forward of the cylinder head on the left side (if you're looking at the front of the engine).
The number you got is probably part of a VIN.
TomZ is offline
Old 12-01-2016 | 04:13 PM
  #139
This is what the man sent me
Old 12-01-2016 | 04:18 PM
  #140
TomZ's Avatar
That's a MK-IV block. Ask him to send you a pick taken directly above the front of the engine (focusing on the timing cover).
TomZ is offline
