New guy with 242 questions >
Old 12-01-2016 | 04:21 PM
  #141
Redneckcustoms13 is offline
Old 12-01-2016 | 04:24 PM
  #142
Hey 79, what prop do you run?
ph1971 is offline
Old 12-01-2016 | 04:26 PM
  #143
TomZ's Avatar
In the picture, the pad with the identifier is under the electrical cable that's running across the top.
TomZ is offline
Old 12-01-2016 | 04:27 PM
  #144
Thanks Tom I'll get him to go take more pictures
Old 12-01-2016 | 04:30 PM
  #145
TomZ's Avatar
You're welcome!
TomZ is offline
Old 12-01-2016 | 05:04 PM
  #146
He says he can't see any other numbers. Oh well.
Old 12-01-2016 | 05:07 PM
  #147
Mercruiser ID tag is on the rear of the block above the bellhousing.
ph1971 is offline
Old 12-01-2016 | 05:13 PM
  #148
Right now I have a 25p mirage plus. I think I am going to swap to a 24p 4 blade though.
79formula is offline
Old 12-01-2016 | 05:20 PM
  #149
You will love the Bravo prop. Makes everything easier. you have a bad bird sir.
ph1971 is offline
Old 12-01-2016 | 06:13 PM
  #150
I just talked to Bob Grissom (might have spelled it wrong) the engine builder. He was very kind and very helpful. He relayed to me this information.
It was an original 454 block
He bored it 100 over he said which makes it a 476 cubic inch block. He used pistons with about 100 thousands dome they have a compression ratio of about 9.75. It is indeed a flat tappet cam shaft but does have roller rockers. He said it is a factory gm 454cu 450hp cam shaft. He said the engine is precision balanced, he put a little aluminum intake on it. Ran it on the test stand over an hour to check it all out before it left. All in all he said it should be around 425 hp or so the way it is. Hotter fuel and more timing might squeeze more from it but it simply a reliable engine as it is now.
