Silent Thunder Removal 89’ 242 LS
Next we ground out all the cracks in gel and any holes that I didn’t want anymore.....these included the upper stern eye bolts that helped hold the platform as well as any other old platform holes and the old trim tab mount holes. Then we filled the cracks and holes preparing for finishing.
Coat the wooden openings for the exhaust with resin to keep out any water intrusion into the transom wood.
I would also fill in the exhaust mounting holes, 3 ea. as your new tips (assuming you are going to replace with nice ones) will most likely have 4 holes.
After we filled all the cracks/holes and sanded, we applied first coat of heavy primer (this one rolled on). When primer was fully cured, we again filled all imperfections and sanded again preparing us for the spraying process.
Now for the details.
We painted the blue at the top again where the name (in white);will go again. We also added the stripe up to the drive......how many of these ole birds have that?
We also painted the top black stripe in same place and added it to carry the lower stripe all the way as well.
